New MacPro and new RME FF800
stainlessbrown
Post by stainlessbrown »
anybody using thew RME interface? I can't get it to be 'recognized". As the MacPro only has FW800 ports I've bought a FW800 cable as well as a FW400x800 cable. The RME came with a FW400 cable....
I'm not sure what the FW800 ports on the RME are actually for, except maybe hooking to another RME, as nothing even shows up in the Mac hardware profile if I plug into the FW800 port. Using the 400x800 cable I get this in the hardware profile
Vendor 0xA35 Device 0x101800:
Manufacturer: 0xA35
Model: 0x101800
GUID: 0xA35004FB534C3
Maximum Speed: Up to 800 Mb/sec
Connection Speed: Up to 400 Mb/sec
Sub-units:
Unknown Unit:
Unit Software Version: 0x1
Unit Spec ID: 0xA35
so the Mac appears to be seeing something, but connected, but it's not recognized...
I've reloaded the software, repaired permissions, but the RME software will only launch if it detects the FF800.
Power is on, Red LED host light is on, as are green LED's at +4dB in/out
DP see's nothing but the internal audio and my MIDI controller
anybody have any ideas?
MacPro 8core, 10MB, 4.5 TB, RME Fireface800, Presonus D8, JBL LSR4326P, Oz HM-6, Presonus HP60, Prism MMA-4XR, Bellari, ART, Altec Lansing, TC Helicon, BBE, 002R, PTLE 8.0, Reaper, Tascam TSR8, Hammond M3, Rhodes 88, Korg, Yamaha, too many guitars, and more mics than I need, and a bunch of plug-ins that seemed a good idea at the time
jlaudon
Re: New MacPro and new RME FF800
Post by jlaudon »
Strange... would you happen to have any other kind of computer with Firewire (or a nearby friend that has one), to try the RME. SOunds like somethings up with the RME itself.
Edit: Just noticed you have a G5 in your sig - have you tried the RME with it?
kassonica
Post by kassonica »
Have you installed the Fireface Mixer and drivers.
The fireface has to be connected and turned on to do so.
It should be all in the manual.
Also make sure you have the Latest fireface drivers, here is a link;
http://www.rme-audio.de/en_downloads.ph ... r_fireface" onclick="window.open(this.href);return false;
1nput0utput
Post by 1nput0utput »
I think some RME reps post on the forums at macosxaudio.com sometimes, so maybe you should ask there.
