Audio Plug-ins mono only issue
Hi, I'm new to the forum as well as DP. Can anyone help with an audio plug-in issue? I've experienced and issue today when trying to use plug-ins. After creating stereo audio tracks I only have mono plug-ins available in the audio plug-in menu. For example, Altiverb only appears as a mono version. Yesterday I had no problems with the stereo version. I am recording MIDI and audio tracks simultaneously via EW Play MIDI channel 1-1 and output channel 3-4 (output Play, input DP track). Any help would be appreciated.
Re: Audio Plug-ins mono only issue
In the Mixer window, the stereo versions of the plugins should appear on the inserts automatically. At least that's how it's supposed to work.
Now, are you not *hearing* the sounds in stereo? Or is it that the stereo tracks only have mono plugins listed?
Tell us a little more about your version of DP and OSX. Also, what are the current settings of your Bundles (Studio menu) and your Hardware Driver configuration (Setup menu> Configure Audio System)?
- cloudsplitter
If your track output is set to a mono output you are only going to see mono plug-ins....your track need to be set to a stereo output such as the mains out 1-2 to see all plug-ins. it doesn't have to be a stereo track just has to be assigned to a stereo output
Mac Pro 3,1 8 core 12 gigs ram Mavericks. DP-8.05 Fractal Audio Axe-FX Ultra, motu traveler, motu MIDI express, 2-24" LCD monitors, Yamaha HS80M,Yamaha NS10M's JBL28P monitors. Mackie control universal, BFD-2, Omnisphere,Trilian Ozone 4, Melodyne Studio/Editor, . Alesis Masterlink. Avalon 737sp. PCM 90. MikTek C4V. Korg Triton Extreme. Paul Reed Smith guitars, MPC-2500 there's more..but that's the heart of it.
- Dan Worley
Since he mentioned he had created stereo tracks, and he's accessing plug-ins from the Audio Menu, he may be seeing the same problem I'm seeing.cloudsplitter wrote:If your track output is set to a mono output you are only going to see mono plug-ins....your track need to be set to a stereo output such as the mains out 1-2 to see all plug-ins. it doesn't have to be a stereo track just has to be assigned to a stereo output
http://www.motunation.com/forum/viewtop ... =1&t=43831
c-ya,
Dan Worley
DP10.13
Dan-- did you run *all* the updates in sequential order after the version on the install disc? Otherwise, some important files might have been skipped.Dan Worley wrote: Since he mentioned he had created stereo tracks, and he's accessing plug-ins from the Audio Menu, he may be seeing the same problem I'm seeing.
c-ya,
Dan Worley
- Dan Worley
Hi, Frodo,Frodo wrote:Dan-- did you run *all* the updates in sequential order after the version on the install disc?Dan Worley wrote: Since he mentioned he had created stereo tracks, and he's accessing plug-ins from the Audio Menu, he may be seeing the same problem I'm seeing.
c-ya,
Dan Worley
My install disk came with 7.2, so I went from 6.03 to 7.2 and then to 7.21. So after using the install disk I didn't skip over a version, like going from 7.0 to 7.2.
Thanks for helping.
c-ya,
Dan
DP10.13
I have the same thing too, it's been like that for some time... I think it is just a display glitch, processing a stereo soundbite does produce a new stereo file (and previews in stereo too)
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
- Dan Worley
You're absolutely right, Stephen! The menu reads mono but they are stereo. Geez, I feel stupid.stephentayler wrote:I have the same thing too, it's been like that for some time... I think it is just a display glitch, processing a stereo soundbite does produce a new stereo file (and previews in stereo too)
Cheers
Stephen
Thanks so much for clearing that up. It saves me a lot of extra work.
c-ya,
Dan Worley
DP10.13
Dan Worley wrote:You're absolutely right, Stephen! The menu reads mono but they are stereo. Geez, I feel stupid.stephentayler wrote:I have the same thing too, it's been like that for some time... I think it is just a display glitch, processing a stereo soundbite does produce a new stereo file (and previews in stereo too)
Cheers
StephenI never thought of just going ahead and trying it. I just took it for face value.
c-ya,
Dan Worley
HI, it's my first post on this forum. Actually I get this same issue with DP 7.21, maybe just a "display glitch", but Stillwell Audio's Bombardier compressor doesn't seem to really like it; when I choose to apply the mono version to a mono file, I get this nasty alert:
and then,half the time, DP crashes...So I think that the problem is not really just in display. I had mail exchange with Scott from Stillwell Audio, he didn't experience this problem before. So i'm thinking now of making an uninstall of DP, then install it again, and install plugins one by one and see....it's giving me headache.
Macpro 2 x dual core Xeon, 3GB ram, X 10.6.4
DP 7.22 motu 828 mkI
••••• Less is MORE •••••
- kassonica
loofa wrote:Dan Worley wrote:You're absolutely right, Stephen! The menu reads mono but they are stereo. Geez, I feel stupid.stephentayler wrote:I have the same thing too, it's been like that for some time... I think it is just a display glitch, processing a stereo soundbite does produce a new stereo file (and previews in stereo too)
Cheers
c-ya,
Dan Worley
Yep it does that on my system as well....
Can somebody post a small project with a text file explaining what steps to take in what order to reliably reproduce this issue? If you can, you can create a ticket on my helpdesk system and attach the file to the ticket.
I'd surely appreciate it.
Scott
Scott
- kassonica
sstillwell wrote:Can somebody post a small project with a text file explaining what steps to take in what order to reliably reproduce this issue? If you can, you can create a ticket on my helpdesk system and attach the file to the ticket.
Scott
Just put bombardier on a mono track.....
@ kassonica: did you resolve the problem with bombardier? I posted a new message to Scott@stillwell, attached a small DP project, screen record and all the stuff but no answer..
- kassonica
loofa wrote:@ kassonica: did you resolve the problem with bombardier? I posted a new message to Scott@stillwell, attached a small DP project, screen record and all the stuff but no answer..
Still unresolved, but I haven't really looked into it either.
