896HD + 828MkII + PT9
I am using Win7 64, current Motu drivers. Not much experience with PT9 but I am able to receive the 8 mic inputs from the 896 into PT, but no success with the 828 inputs. The two are linked together with firewire and I can see both in the motu audio driver and I think in PT. I am not sure if I am missing something in linking the two devices (896 set as clock master) and the levels are up and showing on the 828 meters. They are both synced at 96k and I am able to play back audio without a problem. I have used the two devices successfully in cubase, but that was a while ago.
Re: 896HD + 828MkII + PT9
Resolved the issue. In PT, the 828 inputs show up as Analog 1-8 and then another Analog 1-2. The mic inputs reside on the second set of analog inputs.
Jbird327, I am thinking about going a similar direction with my 828mk3 , 7 64bit and PT 9. Have you noticed any problem with PT 9 not compensating for the delay incurred by the buffer and a/d/a of your motu interfaces?
