Is there a list of MOTU recommended Firewire cards for Win7 64bit? I just went through a lengthy ordeal with Maudio to figure out that there are only certain cards that will work with Windows7.
So, who uses Windows 7 64bit and an 896mk3 and it works? What firewire card would you recommend?
I have a TI chipset FW card and Windows 7 and my profire 2626 didn't like it. Maybe my MK3 isn't so particular but if it doesn't work, I'd like to have some options before I start buying firewire cards willie nillie.
Recommended Firewire PCI Card for 896MK3
- Primary DAW OS: Windows
Quad Core AMD Gateway
MOTU 896MK3
Axiom 61
Sonar X3b Producer
MOTU 896MK3
Axiom 61
Sonar X3b Producer
Re: Recommended Firewire PCI Card for 896MK3
PCI-Express slot card?
I just got a recommended card for my maudio profire interface. I think it's not express. I'll see how it goes. I don't think I have any express slots available. but whatever! what's recommended in either format?
MOTU 896MK3
Axiom 61
Sonar X3b Producer
MOTU 896MK3
Axiom 61
Sonar X3b Producer
I have tested Texas Instruments and VIA ExpressCard for the MOTU 896 MK3. VIA has the best results (SWEEX FW022), so I already have no the best performance possible. I can't set a lower buffer size than 1024 to work without pops and dropouts. I have Windows 7 64 bits, Intel Core i7, 1.66 Ghz, 8 GB RAM... It seems impossible I can't working at 128 samples at 96Khz/24 bits with this hardware on my laptop PC.
MOTU 896 MK3.
DAW: Cubase 5.5.2
PC laptop: Win7 64bit + intel core i7 720 1,66Ghz + 8GB RAM + NVIDIA® GeForce® GT 335M 1 GB DDR3.
Firewire ExpressCard: Sweex FW022 (chipset VIA)
DAW: Cubase 5.5.2
I've used my MOTU Ultralite Hybrid with two different firewire chips, both made by TI, and it worked with both. I suspect you're good to go.
