clock sync for daisy chained MOTU devices
Eralde
Post by Eralde »
Hi!
I know, that connecting 2 MOTU devices via firewire can be a pain in the a%se :cry: (in my case it's a 8pre + 896HD).
But if it's all ok and devices are working properly - what should I do to sync their clocks ? Which connector should I use for this purpose?
Will they be a master/slave when daisy-chained (like with ADAT connection)?
Thanks in advance!
jian
Re: clock sync for daisy chained MOTU devices
Post by jian »
Adat sync seems to be the easiest way to
sync multiple motu devices. Set 896 as master
and 8 pre as slave and you should be good to
go. I use similar set up with 828mk3 and 8pre
with good results.
