Is it possible to connect PS3 to 828 mkIII?
ronjams
Post by ronjams »
I haven't actually made the connection yet but I was hoping someone already tried this combination already here on this list. Does it work? If so, please provide step by step instructions. Thank you. By the way, for those who may not know the PS3 provides s/pdif connections.
Mac Studio M1 Max DIGITAL PERFORMER1248/8pre ESFalcon/kontakt/Unify & A LOT MORE GEAR
mess
Re: Is it possible to connect PS3 to 828 mkIII?
Post by mess »
No. The PS3, like most all other entertainment devices, spits out an encoded single stream signal that is decoded by the surround receiver ont he other end.
The 828 can only send and receive ADAT Optical or TOSLink (depending on the model) which provide discrete audio channels.
ronjams
Post by ronjams »
What about with the mac pro optical connections?
ronjams
Post by ronjams »
Okay this setup wont work but what about connecting the PS3 via s/pdif to the mac pro first and then coming out to the 828mkIII could that possibly work?
mess
Post by mess »
Actually, I think the PS3 might offer the ability to output a PCM stream over Optical which would allow you to output discrete channels. Try digging through the menus to see if it's possible.
One caveat - I'm not sure if it includes a clock signal or not.
carrythebanner
Post by carrythebanner »
mess wrote:Actually, I think the PS3 might offer the ability to output a PCM stream over Optical which would allow you to output discrete channels. Try digging through the menus to see if it's possible.
I have a DVD player which has six analog outputs for discrete surround outs, and coax/optical digital outputs for encoded surround; you can change the digital outputs to be PCM rather than encoded, but they will be stereo only rather than surround. I don't have a PS3 to say if it's the same, but I wouldn't be surprised. I think manufacturers (of consumer devices) tend to shy away from full-quality multi-channel digital outputs, presumably because of piracy fears.
mess
Post by mess »
http://manuals.playstation.net/document ... utput.html" onclick="window.open(this.href);return false;
I'm not in any position to test this out, but maybe the OP can give it a swirl-a-whirl and let us know if it's great success or utter failure.
ronjams
Post by ronjams »
OP or anyone else with more experience in this area please test to see if what I'm suggesting can actually work!!!
