Moderator: ssp
you could at least use it before trashing it? if you suspect its not for you already then return it unopened for your money back.djblunt wrote:It appears I may have. I just ordered it today, AND THEN came across this forum. Perfect timing. I've been reading through this forum, and all I've read are negative reviews about BPM. I should've went with my better judgement when I couldn't get a straight answer about BPM having the 16 level auto-chromatic feature like the MPC 20000xl
(which I have found out AFTER BUYING IT that it does not
). The only reason I'm getting it is because of the library. I have heard that the sounds are good, despite the workflow of this program, which apparently is pretty bad to say the least according to what I've been reading here. Is there anyone here who has something good to say about it? And, is there a work around way to get a sound to be spread "chromatically" (pitched/tuned) auto/semi-automatically? If I have to program each pad individually to do this, I'd rather just use my MPC.
+1 Probably the best drums and one shots around. Great stock effects and filters. Too bad there are serious bugs we are waiting so long to get fixed.I do know one thing for sure about BPM, the sound quality is PRO!!! These R&B hits and snares will crack your face off in a mix!
