424-->424??
dementedchord
424-->424??
Post by dementedchord »
hi... i'm thinling of a major change for me and wondered if this might be a quick solution...
i've been using a tascam fw controller of late but recently copped a soundcraft series 500 desk that i'm hotrodding... planing on useing i/o24 to get the board integrated... i'm also planning on offloading vstis to a separate box which i can take out for keyboard gigs... my question then is when in the studio assuming i have a 424 in both boxes will i be able to send the vstis in box b to box a through their respective cards... make sense??? thnx in advance...
1nput0utput
Re: 424-->424??
Post by 1nput0utput »
No, you can't connect two PCI-424 cards together directly. The best solution would be to have 2408mk3s connected to the cards, and then connect the 2408mk3s by ADAT optical.
dementedchord
Re: 424-->424??
thnx for the quick response/// interesting... on the face of it you wouldn't think it would be difficult... ie. how different would the output from card B look as compared to a 2408 to card A... perhaps something in the handshake... any other ideas??? i had previously considered ethernet and probably end uo going that way unless someone comes up with a better plan... thnx again...
