Can someone look inside their Mach 5 manual and tell me what it says re: minimum computer requirements? I want to see if DP4.5 and Mach5 will run on a Mac G4 733 (640 megs RAM so far) without choking it too badly.
-Dale.
Mach 5 Minimum Computer Req's
Re: Mach 5 Minimum Computer Req's
Hello
You'll be able to open and run mach five with those specs. A lot of your performance will depend on the samples you will be loading into the mach five as well as the amnt of instances you plan to run.
--Bryan--
--Bryan--
http://www.dfabstudios.com/" onclick="window.open(this.href);return false;
http://www.dfabmusic.com/" onclick="window.open(this.href);return false;
