Hi all,
Since a few days that I use dp 4.52, if I get for any reason a CPU spike, the sound wich is played "live" in M5 have little crakles.
EXEMPLE :
I create a new Project with only one MIDI track and one M5 track wich contain only one part unabled with a piano sound.
Everything's OK with the sound till a don't have any CPU spike.
I launch UVI-Xtract, so I get a CPU spike, as every time I launch UVI-XTract if buffer size lower than 1024.
After I've leaved UVI-Xtract the piano sound has littles crakles.
If I do the same experience in dp 4.12, I never get those crakles.
Does any body got this kind of bug?
G5 2x2
4 Go Apple RAM
OS 10.3.7
Christophe
dp4.52 crackles with M5
Re: dp4.52 crackles with M5
lower the volume on the M5 channel. i get the same thing sometimes because it's distorting inside of the M5.
el Ocho 2.8 running DP6 & RMX with M5II - 828mkII / el Quatro 2.66 running Vienna VI & Vienna Ensemble, RAX 2, M5II & L8 for VSL - 2408mkII / steiner MIDI EVI, Oberheim Xpander, M5II reading UVI .dats, Radium 61 controller
http://www.ronmeza.com
Paris mini studio : iMac 20" intel 2.66 core duo (spring 2009) DP 6.02 - Firebox running M5II & Independence Pro 2.1 connected to Mac Mini (spring 2009) - Firebox running L8, RAX 2, Independence 2.1, M M5II
Keystation 49e controller
