memory or cpu?
memory or cpu?
i just did a project where i was running 9 channels of mach 5 samples and my computer got really slow. is it memory or cpu?
g5 1.6 sp/1gig ram/os10.3.8/dp 4.52
- Percy the Burp King
Re: memory or cpu?
The first thing I would do is to install the maximum amount of Ram that the machine can handle.
A dual-processor upgrade might be a later consideration.
I'm working on a demo on my older system that has 8 channels of M5 samples with system responsiveness although the cpu meter is at max.
Re: memory or cpu?
I have A g5 Dual 2.0,and I have been running about at least 30 channels of machfive or more,Plus Sampletank le and Soniksynth2 about 2-4 channels each,and my cpu still is not half way up!I only have 1 gig of ram also.Originally posted by jackorhythm:
Maybe it's the dual prossesing.But also try elemenating any unnecesary polynphony counts.
This also helps greatly.
Just testing this thing out
Re: memory or cpu?
thanks. can you explain please?Originally posted by Jason Gaines:
try elemenating any unnecesary polynphony counts.Originally posted by jackorhythm:
This also helps greatly.![]()
Re: memory or cpu?
Well Polynthony means the amount of keys that are playing simutamiously.Like say you are only playing about six keys simu"On say channel 6 of machfive,Well if it is still set at 30 wich is Default,than It will take up a whole lot more CPU power than about 8!Lowering this helps greatly,Trust me I have tryed this.Originally posted by jackorhythm:
<small>[ May 29, 2005, 02:31 PM: Message edited by: Jason Gaines ]</small>
Re: memory or cpu?
how do i do this? in m5 i assume? prefs?Originally posted by Jason Gaines:
Polynthony means the amount of keys that are playing simutamiously.Like say you are only playing about six keys simu"On say channel 6 of machfive,Well if it is still set at 30 wich is Default,than It will take up a whole lot more CPU power than about 8!Lowering this helps greatly,Trust me I have tryed this.[/QB]
Re: memory or cpu?
No It is on the right side of the waveform Editor.Originally posted by jackorhythm:
how do i do this? in m5 i assume? prefs?[/QB]Originally posted by Jason Gaines:
Polynthony means the amount of keys that are playing simutamiously.Like say you are only playing about six keys simu"On say channel 6 of machfive,Well if it is still set at 30 wich is Default,than It will take up a whole lot more CPU power than about 8!Lowering this helps greatly,Trust me I have tryed this.![]()
<small>[ May 29, 2005, 05:36 PM: Message edited by: Jason Gaines ]</small>
Re: memory or cpu?
dude-
you rock with high authority. as i assigned each part to a lower number the computer got that much less sluggish until it finally started behaving normally by about the the 5th part set at 8 voices.
thanks for the tip.
thanks for the tip.
Re: memory or cpu?
No ProblemOriginally posted by jackorhythm:
dude-
thanks for the tip.
Re: memory or cpu?
A heads up: the word is "polyphony."
Re: memory or cpu?
O,My badOriginally posted by chrispick:
