Basically this box did not work well when new with Mac OS 9.1 (freezing LEDS) which I had to fix by unplugging and holding down panic button for 15 seconds.
Yes it's the removeable rack-ears 2002 version. Finally I had to remove battery to do a hard reset when it completely froze (LEDS) and presets would not change. Actually, rather than removing battery temporarily, just replaced battery, low amperage the problem with many lithiums, not low voltage. So don't trust a simple voltage meter. The warranty had expired anyway. But I would contact tech support first. Only two screws and the top comes off. Unlike some boards, battery is not soldered in.
Mac OS 9.2.2 with the same Micro Express is working flawlessly with fresh battery, so I dare not change eproms or touch it. But not on XP Pro, and I've tried all three drivers. On SP-2 I had a little success with the oldest driver SetupMidi 2004 something... then it stopped being recognized. No errors in device mgr.
I do not have the option in Asus bios for legacy plug and pray support. On/Off only. This is from a Motu tech note -- legacy should be enabled in PnP bios. I do have legacy USB support turned on 'automatic' in bios. PnP was turned on in bios, but I just turned it off to let XP run PnP as a test and still no cigar, even though device mgr shows all three drivers installed and 'working'. This is the most recent Asus bios version W-7 64 compatible with XP 32 also. Clockworks cannot find device. Reaper cannot find device. Standalone Kore Player cannot find device. However, this box did work once SP-2. Realtek HD audio disabled by Delta 66 card. I even turned HD audio off in Bios still no cigar. I am on SP-3 now... no MIDI input period. So I sneaker net over from the noisy mac.
If anyone has any suggestion as to how to get it working I am open to it. As I have an Opcode midiport32 USB just no XP drivers. I lock two machines for polyrhythms.
>>>>>However, I just read that an m-audio 'two plus two' with no W-7 64 bit drivers from Avid is recognized by Windows 7 64 bit sans installation and runs well with built-in MS drivers. That's good news huh? No driver hassle at all? Let REAPER time stamp if need be (it has three options and can be turned off).
I mean who wants a solo MIDI interface? Yet this is all the stores carry. Apple made these back when the Mac SE was released!!!!
I guess people don't use synths anymore or employ alternate tunings... but I digress.
Windows bashing... look. Apple build quality has gone way down. But they do have a very good engineering staff. If you could hear side by side a G-4 vs a Quad Core running at 32-34 F in an Antec P-183 case. There is no comparison. Literally. The G-5 was even worse. I've suggested to Apple they put that darn internal speaker on the G-5 or MacPro to good use, and cancel the fan whine...
Oh.. one more thing. With a USB-2 Audio/MIDI interface you can prioritize drivers. Micro Express is USB 1.1
Isosynchronous link layer mode is the fastest, but no CRC, probably what RME is coming out with soon. Good cables with dual ferrite beads are a must: http://www.kimber.com" onclick="window.open(this.href);return false;
This is why RME and Apogee are having such success with the new Intel Chipsets with USB-2. USB-3 not yet incorporated into next year's chipsets.
Sys Ex are you retuning plugins or MMC? Did you turn powermanagement off on the USB hubs? Power on all the time?
RK
Interesting Quote: "Engineers are retarded. They must have some sort of brain damage or something..." Ray Meeks, Apple Computer, Quicktime Developer, SoundManager Developer
Arrrg! Quicktime
