Perplexing File Path Issue
i migrated some old projects onto a storage drive a few years ago.
i did not need to open them until now.
when i open them it states that there are files missing, but all of the files are in the audio files folder.
it is looking for a path of an old drive that is no longer there. (the original drive that the project was initiated).
is there a simple way to relink the "missing" to the corresponding files that exist in the audio files folder?
i work in final cut pro for my day job, and this can be done fairly simply.
any help would be greatly appreciated!
thanks!
kraig
thanks!
kraig
- FMiguelez
Re: Perplexing File Path Issue
I've never dealt with this, but I think DP gives you a chance to tell it where the files are (in the same dialog box that alerts you of the missing files). You should be able to point DP in the right direction there easily.
Hopefully someone with actual experience doing this will chime in shortly.
Also, there's no need to post the same question twice in different forums.
Yes... please do not cross post. It does not belong in the other forum you posted in and I have to delete it now.
sorry about cross posting.
as soon as i posted in the first forum (which was the wrong one) i realized my mistake.
i thought i deleted it in the incorrect one.
sorry for the inconvenience.
- FMiguelez
What about your issue? Did you try the suggestion?
yes i solved it, thanks!
but in an unconventional way.
the problem only occurred in DP7.2.
i reopened the projects in 7.12 and they opened without a hitch.
i then re-saved them (duplicating all audio), and then opened in 7.2 with no issues.
thanks for your input.
kraig
kraig
- Dan Worley
7.21 fixed this issue, and another very serious one when deleting unused soundbites. I would strongly suggest you install the 7.21 upgrade.kraigmason wrote:yes i solved it, thanks!
kraig
c-ya,
Dan Worley
DP10.13
Thanks for the advice.
DP7.21 Installed!
kraig
DP7.21 Installed!
kraig
