A tip about removing mouth noise
Dan Worley
Post by Dan Worley »
I thought I'd pass this along because it's a huge time saver:
I'm editing an audio book (which I love doing) and was fighting getting rid of some unwanted mouth and throat noises (outside and within the words). These can become glaringly obvious and annoying when you get things up to level.
I had downloaded the demo of RX2 the other day and I thought I'd give the DeClicker module a shot at getting these noises under control (that's not exactly what it's designed for but I figured it just might work). I'm happy to say it worked wonderfully. Wow! This is going to save me tons of time and the audio books will come out sounding better than ever.
The setting I found that worked best for this project was "M-Band random clicks' with the sensitivity set to 26.
You'll need to merge the track before bouncing or you'll get dropouts in the bounce. This plug looks way ahead and if there are too many soundbites due to edits it can't handle it during the bounce. It does fine with real-time playback so no need to merge the track until it's time to bounce.
It should work with music (singing) tracks, too.
c-ya,
Dan Worley
DP10.13
daniel.sneed
Re: A tip about removing mouth noise
Post by daniel.sneed »
Thanks Dan.
For sure, I'll try this one ASAP.
Dan Worley
daniel.sneed wrote:Thanks Dan.
Please let me know how it works for you, Daniel. Oh, I forgot to mention, it's interesting and helpful to solo what's being taken out. The plug has a control for that.
c-ya,
Dan Worley
DP10.13
daniel.sneed
Dan Worley wrote:[...]Oh, I forgot to mention, it's interesting and helpful to solo what's being taken out. The plug has a control for that.
I consider it as one RX strong point. Really a helpful feature.
