mach5 waves
mach5 waves
How do you get mach five to see your wave files you have in the sound folder
Re: mach5 waves
Hello
Make sure you have it all set up correctly. In other words, make sure that the your folders (soundbanks, presets, samples are set up correctly). Look at the tutorial sounds for an example how file structure should appear.
Aside from that, you can try re scanning the M5 sounds folder. Are you able to load all other samples fine except for the waves you have loaded ?? How did you go about loading the waves into M5??
--Bryan--
--Bryan--
http://www.dfabstudios.com/" onclick="window.open(this.href);return false;
http://www.dfabmusic.com/" onclick="window.open(this.href);return false;
Re: mach5 waves
You must mean WAV files. The title of this made me think the subject is about MachFive and Waves plugins. But...Originally posted by dat:
It's Page 62 in the MachFive manual. They show how to drag, drop and map the samples there. WAV files should work smoothly.
