DAE driver is missing
- tobysan
I just got Rosetta 800 and DA 16X, I recently installed Logic 9 and its working fine.
still need to be able to use DP so I upgrade to DP 6.03, When I try to start DP I get this error:
The DAE driver is missing or is not in the DAE folder within your System folder. Check the DAE's location and relaunch Digital Performer.
Also i cant change outputs,
Any idea ?
Thanks !
Any idea ?
Thanks !
Mac pro 8 Core 2.8GHz, 10G RAM, OSX 10.5.6, DP 6.02
PCI 424 e, 2408mk3, MTPAV,rosetta 800, BigBen WC
Latin Music production and songwriting..
www.myspace.com/tobysandoval
Re: DAE driver is missing
Did you install Pro Tools prior to installing DP? DP's installer readme notes that doing so is necessary for DAE to work properly. Also, what version of PT is installed?
- tobysan
Thanks,
No i don't, never installed PT on my machine,
Logic 9.1.1
MTPAV
Melodyne
Rosetta 800
AD/16X
Logic 9.1.1
MTPAV
Melodyne
Rosetta 800
AD/16X
If DP is starting up with that error and you can access the DP menu, under menu Setup --> Audio System select the MOTU Audio System rather than DAE. Or maybe try trashing DP preferneces.
DP8.06 PT11.2.0 VEP 5.3.x
If you want to use DAE mode in DP, you'll need to install Pro Tools.tobysan wrote:Thanks,
There's a good technote on MOTU's site with compatibility info for DAE mode showing which versions of DAE are compatible with which versions of DP: http://www.motu.com/techsupport/technot ... patibility" onclick="window.open(this.href);return false;
That said, if I recall correctly, DAE mode in DP 6 was a bit of a mess; the DAE guys here could fill you in on the details, but I'm pretty sure that things never really cleared up until DP 7.
- tobysan
Thanks friends !
I select MOTU Audio System and it fix it, after install Logic, i don't know why DP its trying to open under DAE.
