Bounced Track adds unwanted FXs
ferchman
Post by ferchman »
I've just finished a mix where my bounced track sounds significantly different than what I monitor in real time. The bounced track presents as if a slap-delay has been added to the entire mix. Other descriptors: Ld Vox, kick, snare, and other parts sound panned right. The left side is sounding the slap-delay.
My routing is this:
Master Channel is sent to an Aux Track and then bussed to a Stereo Track.
In the Master Channel I have two plugins:
• SSL Compr (with slight finalizer setting)
• MOTU Trim (for peak monitoring)
Aux Channel has 2 plugins:
• MOTU TRIM (add 2.5 db)
• WAVES L2 (slight Limiting)
I have used this procedure many, many times and never had a problem. Does anyone out there have any insight?
DP 7.21, 2.66 MHz Quad-Core Intel Zeon, 8 Gig RAM, OS 10.6.4, 2408 Mk3 (Black Lion upgrade), MOTU 828 Mk2, Seventh Circle Audio N72/NEVE 1073 Pre (4), Seventh Circle Audio A12/API (4), UA 6176, UAD-2, WAVES Diamond, NI Komplete 7, Mach5-2, blah, blah, blah...
waitsongs
Re: Bounced Track adds unwanted FXs
Post by waitsongs »
I don't have much insight, but I have a similar thing happening when I bounce a mix that has the AAS UltraAnalog synth in it - the patch changes back to its default settings, even though I've saved my own settings as a new preset. It does this during the BTD, so the bounced mix uses the wrong settings. FWIW, this happens in 7.21, 7.2, and 7.12, so it's not just a 7.2 issue. I haven't tried it in any version of DP prior to these.
The good news is, I can do the old reliable workaround -- a real time mix to a stereo audio track -- then bounce that mix to get the various other formats I need.
Aside from this problem, I'm crashing a lot with 7.21, especially if I delete too many Chunks. If I delete more than two at a time it will crash on Save, or if I delete one, then save, then delete another, then save, I can delete a total of four, but the next one will crash DP as soon as I save. Kind of irritating....
DP 8.06, OS X 10.8.3, 8 core 2.8gHz MacPro, 14 GB ram, 32 Lives and JBridge, UAD-2 Quad Satellite, 828mk3, Apogee AD-16X, Trak2 and Rosetta, Eleven Rack, EWQL Gold Pro, Colossus, Goliath, Ethno World 4, StormDrum2, Komplete 8, LASS, MX4, Soundtoys Bundle, Stillwell plugs, Ozone 5, Slate Bundle, Trash, Waves C6, H-EQ, Autotune, Abbey Road plugs, Pro Tools 10, Logic 9, Reason 6.5, Final Cut Pro, lots of mic pre's, mics, instruments....
waitsongs wrote:I don't have much insight, but I have a similar thing happening when I bounce a mix that has the AAS UltraAnalog synth in it - the patch changes back to its default settings, even though I've saved my own settings as a new preset.
I don't know if UltraAnalog responds to patch changes or not. I wouldn't think so, but even still you might want to see if you've set a default patch in the default patch column in the Tracks Overview.
waitsongs
Post by waitsongs »
James Steele wrote: I don't know if UltraAnalog responds to patch changes or not. I wouldn't think so, but even still you might want to see if you've set a default patch in the default patch column in the Tracks Overview.
Thanks James. Great suggestion, but I haven't touched the default patch settings column (and nothing's showing up in there that I may have set accidently). The only weird thing I'm doing though is setting the bpm in UltraAnalog to half the sequence tempo as a quick way to cut the arpeggiation in half. Maybe this is user error to do it this way, but it plays back correctly until I bounce to disk. This isn't a killer issue for me, but I posted because I wanted to remind the O/P to try mixing to a stereo audio track as a workaround when BTD doesn't seem to deliver the desired results.
ferchman
Post by ferchman »
waitsongs wrote:This isn't a killer issue for me, but I posted because I wanted to remind the O/P to try mixing to a stereo audio track as a workaround when BTD doesn't seem to deliver the desired results.
I have mixed down to a stereo track (in real time) and still have the same problem.
I've been wondering if there is something wrong with the file itself. Is there a way to open a new file and load ALL the mixed items from the old file (including automation, plugin settings, levels, soundbites, etc.)?
FMiguelez
Post by FMiguelez »
ferchman wrote: Is there a way to open a new file and load ALL the mixed items from the old file (including automation, plugin settings, levels, soundbites, etc.)?
Use the Load command for this. Check the options you wish to load (Bundles, Audio, etc.).
Have you checked your busses? Perhaps you have a duplicated output with different names in a bundle...
ferchman
Post by ferchman »
I will check the buss assignments again. A duplicated buss routing would make sense. Thanks.
