Piano UFS Crashes MachFive2
fastriffs
Post by fastriffs »
The other sounds load with no prpoblems. Anything from DVD2-piano's will crash MachFive2. MOTU tech support was not reachable by phone. I think something nust be wrong with the UFS file or maybe the disk is bad. I am using WinXP x86 if it matters.
Re: Piano UFS Crashes MachFive2
I'm not on a PC but is there a disk utility you can run to test the DVD disk? Also, so you have another VI player (UVI, etc.) you can try to load the file on to?
Have you copied the UFS to your HD? Sounds like a simple question, but you never know...
Either a Techlink or call to MOTU is certainly in order in any event. Good luck.
carrythebanner
Post by carrythebanner »
Is disk streaming turned off? If so, MachFive is probably just choking on trying to load an 8 GB preset (since MachFive isn't 64-bit).
joker77
Post by joker77 »
WinXP x86 - hw much ram do you have in the machine? I remember having alot of issues with XP due to not having enough memory,perhaps this is the issue.
Mac:Mac Pro 8 Core|12GB Ram|Lion OSX 10.7.2
Hardware:RME Fireface|Alesis Q7|Lavry AD/DA|Grace 101|FocusritePre|Presonus Monitor Station|DynAudio Bm5a Mk2|Event
Software:Maschine|Emulator X3|Mach Five 3|Geist|UVI sound libraries|Pro Tools 10|Logic 9|Studio One Pro 2
