i made a bad update on my motu hybrid , no it tell me:
cpu not valid , update firmware
ul mk3 HYBRID boot v 1.00
WHAT TO DO???
motu hybrid wrong update firmware !!
Re: motu hybrid wrong update firmware !!
I ACTUALLY PUT THE 1.02 FIRMWARE FOR TRAVELLER...DAMNNNNNN!!!
I suspect you're going to need to obtain the Ultralite Hybrid MK3 firmware, and load that into your unit. Since the UltraLite blindly accepted the firmware for another unit, I'm assuming the firmware loading code in the unit is entirely separate from the OS firmware itself. So even though you've got the wrong firmware in it now, obtaining and loading the correct firmware should fix the problem.
Unfortunately, it seems that MOTU doesn't make current firmware available until there's actually some update to it. So you'll probably need to get in touch with tech support.
THANKS a lot J-e-f !
i create a tech link on motu on week ago, but it still unread!!
is anybody on this forum had the same trouble??
what motu did?? do i have to send back the card to them??
now everything is ok!! motu tech link sent me the hybrid v 1.02 updater!
so if you got the same trouble just contact them
