Opening standard MIDI files crashes DP 7.12 (!?)
AleCerto
Post by AleCerto »
It looks weird but I can't open any MIDI files in DP 7.12 any more.
DP crashes each time I try to open a simple standard MIDI files:
- I open a MIDI file
- the "rainbow wheel" appears
- BOOM! DP crashes!!
I have the crash log but it's long and I don't want to waste the forum space (let me know if you want me to post it here).
The last time I opened with no problems a standard MIDI file in DP 7.12 has been on the end of July (both via menu command "open" and "drag and drop" to DP).
In the mean time I added to my setup Audio Ease Altiverb 6, both AU and MAS, and I also had a few problems with the CoreAudio driver - I usually use "Digidesign HW (HD)" - because I launched DP while Digi HW was off (DP switched to "MIDI only" but after a while it crashed).
The MIDI files I have to work with are ok and are not corrupted (I checked them both with PT and QuickTime Player).
I also tried with some MIDI files generated a few months ago by DP itself but the problem is always the same: DP crashes!
It looks like something has corrupted somewhere and/or something else is badly interacting with DP, but I can't figure out what it could be (Altiverb may be?).
Since I needed to use those MIDI files, I've also - stupidly - upgraded to DP 7.2: same crash problem plus DP 7.2 cannot handle my "old" projects (i.e. DP 7.2 looses all the audio files references/names/paths... a true nightmare).
So I downgraded to 7.12 or I hope I did it at least: I simply trashed the 7.2 version application, but all its "new" files are there interacting with DP 7.12, is it safe?
May I need to perform a clean install of DP 7.12 (I have the original DVDs and all the upgrades MOTU released, but I've no idea of what I have to trash or not)?
Or have I simply to trash some preferences or such?
Do you DP gurus have any suggestion and/or ideas?
My setup:
MacPro QuadCore 2,66GHz
OS 10.5.8
DP 7.12 (with some 7.2 stuff)
PT 8.0.1
MachFive 2.0.2
Komplete6
Waves Diamond 7.09
Altiverb6
PTHDAccel+192
TIA
Ale
MacPro QuadCore 2.66GHz, 16 GB RAM, OS 10.11.6 & 10.8.5, DP 9.12 & 8.07 , PT 12.7 & 10.3 & 11.1, MachFive 3.21, Komplete10, Waves Diamond 9, PTHDX+HD I/O, MTP AV
adriano
Re: Opening standard MIDI files crashes DP 7.12 (!?)
Post by adriano »
Ciao Alessandro, come va?
Sounds like something got corrupted and DP 7.2 it's a very good update. You should not have any problems with it. Here is what you should do first
Go to:
User>Library>Preferences> and delete the Digital Performer folder. Update to DP 7.2 again and then work from the new version. This should clear things. If not, please post back.
Ciao,
Adriano
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
