after upgrade-how to remove old OS 9
- Kellog
How do you guys remove the old OS 9.x after upgrading and determining stability. I want to keep files but remove the OS. Suggestions? Thanks Kelly
Mac mini (2018) 3.2 Ghz 6 Core Intel Core i7 w/64 GB ram, OSX Catalina 10.15.7, DP 10.13, UAD Apollo Quad, Komplete 13 Ultimate, Superior Drummer 3, EZ Keys, EZ Bass, EZ Mix 2, Stylus RMX 1.7f, Avid Eleven Rack.
Re: after upgrade-how to remove old OS 9
DON'T DO IT!
You may need to go into Classic mode at some point and you will want that OS on your system. No OS, no Classic mode! Even after a couple of years, I still find an occassional file that needs an OS 9 program to run (so don't delete any programs you haven't confirmed are updated to OS X, either!
A SECONDOriginally posted by KELLOG:
NO NO NO!
MIDI Life Crisis is correct.
You may find your self in serious trouble in the event you can't sighn into OS X so then at least you can sign into 9 and solve the problem from that OS.
OS 9 does not take up that much hard drive real estate. In my NINE I reduced the browsers down to one favorite ( mozilla ) and trashed the other browsers.
Mac OS: Mojave
