i'm using VE Pro on my slave Quad Core 2 x 2.66 w/16 GB RAM and am using PLAY in several instances of VE PRO. Playback is generally fine into my host machine w/DP7.2. But when i go to bounce the MIDI their are a lot of glitches and stutters. The Kontakt 4 stuff seems to bounce ok though...?
Anyone had this issue and what can i check off the list that might be causing it?
i also found glitchiness and drop outs when i go to freeze tracks. is this because PLAY is still not 64 bit and my machines are not fast enough? In some ways i had less issues with Bidule just running on single machine (2 x 2.66, Dual Core Mac Pro) although playback could sometimes get overloaded. I want to get the best out of this setup without work arounds anyone?
i've got DP prefs set to playing all VI's in real time.
Bounce MIDI to disk VE Pro/EW PLAY/DP 7.2?
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
Re: Bounce MIDI to disk VE Pro/EW PLAY/DP 7.2?
anyone?
DAW:DP8.05
VI's/Plug-ins:
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
