828MK3 Windows 7 x64 memory issue ?
Hello @ all,
does anybody know if there's also a problem with Windows 7 x64 and the 4GB memory limit? I have no sound in any application.
I read that this problem exists with 828 mk2.
The Workaround with "bcdedit /set removememory" doesn't work.
BTW: The latest driver is installed correctly at
the 1394 OHCI Compliant Host Controller (Legacy)
THX a lot
Uncled
THX a lot
Uncled
Re: 828MK3 Windows 7 x64 memory issue ?
I have Windows 7 Professional x64 with 8GB memory and my 828 MKIII working good ( I have only issues when playing iTunes music together with browsing Internet = get some pops and beeps when any www have huge amount of pictures / animations ) ASIO works great under Cubase 5 - PCIExpress TI based FW card with legacy driver.
Hello Drummer_CZ,
thanks for your response.
I dont' get any sound of Windows, VST or other Apps.
Did you configure something special?
I used Windows XP before and had no problems...
Now I use Win7 Ultimate x64 with 8GB
Greatz
Uncled
Greatz
Uncled
ive got the same promplem ,,i have windows 7 64bit, qard core amd ,and 4 gig ram , 828mk2 , the sound is very disorted , ive tryed driver apon driver , evan wiped windows 7 ,and put it bac , can some one help
as i said down below , the promblem is not windows 7 , i have mi4 old steinberg sound card and had no promblems wiv it , my motu runs fine on xp ive just tested it, i had it runing on xps for 2 years , frist year i had it was madness but then motu came wiv the right drivers and it worked like a dream , i think its a 64bit promblem , and the drivers wat motu have given out today ,just dont work proper ,windows 7 runs very well, wen it comes too makeing muisc , blows xp away , i dont understand why you put drivers out wat just dont work propley , 64bit thing ,most people are swicthing too , so plz motu help .i have distored sound and it sounds like a blown out speaker ,help!!!!!!!!!!!//////////////
uncled wrote:Hello @ all,
THX a lot
Uncled
hi ive got sound but its very distorted ,,i have qard core amd and 4 gig of ram in the comp so far
Have you tried contacting tech support? Maybe they can help you figure out what is causing the problem.xbass247 wrote:as i said down below , the promblem is not windows 7 , i have mi4 old steinberg sound card and had no promblems wiv it , my motu runs fine on xp ive just tested it, i had it runing on xps for 2 years , frist year i had it was madness but then motu came wiv the right drivers and it worked like a dream , i think its a 64bit promblem , and the drivers wat motu have given out today ,just dont work proper ,windows 7 runs very well, wen it comes too makeing muisc , blows xp away , i dont understand why you put drivers out wat just dont work propley , 64bit thing ,most people are swicthing too , so plz motu help .i have distored sound and it sounds like a blown out speaker ,help!!!!!!!!!!!//////////////
after installing the new drivers (4.0.42114) everything seems to be alright again !!!!!
