Hi,
I just recently got my board all patched into my 24io in the hopes of being able to use all the mono outs to mix down analog. I came across a seemingly unusual problem though...
Cubase (sl3) shows that it is outputting on all channels, no matter which, monor or stereo that I choose, but the MOTU only meters and outputs on mono channels 1 and 2 and only on stereo channel 12 (mono outs 23 and 24). Anyone experienced this sort of thing before? Anything I may be overlooking?
New to the forum, but help would be greatly appreciated. Thanks.
-Harold
24io problem...limited outputs??
Re: 24io problem...limited outputs??
Problem solved. Sounds newb but I restarted the PC and the MOTU again...which I had already tried 4 times...and everything functions now. Why this sort of thing happens every time I install something new to my setup is beyond me, but Im glad its working!
For others having this type of issue...the Cuemix console can also cause this type of problem, so keep it up to date and restart it if something fishy is up. I know from experience.
