Having Mach Five 2 vst issue with windows 7 64 bit
I am able to load mach five v2 stand alone with no problem in 64 bit windows seven. But when attempting to load mach five as a vst in sonar 8, it usually stops when trying to load the .dll file and i have to cancel. I have tried uninstalling and reinstalling. and Mach Five allows you to install 32 bit or 64 bit with a yes/no prompt. I always make sure I choose the 64 bit option. How do I get mach five 2 to come up as a vst in sonar using the 64 bit windows 7 operating system. SOMEONE HELP PLEASSSEE!!!!!! is there a patch I need or what?
Re: Having Mach Five 2 vst issue with windows 7 64 bit
MachFive 2 isn't 64-bit native — the 32/64 selection in the installer is just for the iLok drivers.
- beejeh
This sounds like the problem I had with Windows 7, drove me demented !
It's a conflict with Internet Explorer 8 and the Ilok drivers believe it or not !
Read my solution in the Sonar forum :-
http://forum.cakewalk.com/tm.aspx?m=202 ... print=true" onclick="window.open(this.href);return false;
Regards.
Machfive 3.0.3, PC user;
Sequencer=Sonar Producer X1 expanded. Using ASIO drivers.
O/S=Windows 7 Ultimate 64 bit. CPU=Intel Q6600 Quad core 2.4GHz, Mobo=ASUS P5K Premium WIFI AP (Black Pearl), Graphics=GeForce 8800GTX, RAM=8 GByte, Music H/W=Motu 828mkII & MTP/AV + Creative Audigy 2 ZS Pro Platinum
Also Macbook Pro OSX 10.6.7 user with Logic 9.
