Kubi wrote:
The only time I turn DP's dither off is when I export a soundbite from the soundbites window. Not 100% sure, but I believe that is a DP function. When exporting a soundbite unchanged I of course don't want dither added, so I turn it off, to be safe. Would love to hear from MOTU/MagicD if DP's dither (when checked) gets applied when exporting a sound bite at its original bit depth and sample rate.
Here's something perplexing:
I'm not so sure if Dither is working at all during an export.
Keep in mind I'm using DP 6.03.
I took a 24-bit mix. I exported it twice as 16-bit from the soundbites window, the first with Dither off, the second with Dither on. I imported the resulting files into a 16-bit project. Auto Conversion off. The files were not changed in any way. Did a null test. The two tracks canceled out completely. I have the monitors cranked to 12. There is absolutely no noise. No hiss, no hum, no phantom noise, no clicks, no pops, no rough edges. There is no residual noise at all... but there should be.
So, no matter if it's checked on or off, either Dither is not working at all during export, or it's working all the time.
I did this test three times, all with the same results.
c-ya,
Dan Worley
