NO"Try deleting the two entries SidSpeed and SidSpeedOld. Are you able to right-click and delete these SidSpeed entries?"
(From previous call.. tried restoring default security settings from microsoft support. However, user is unable to access/create/edit values in the registry. Suggested troubleshooting OS with Microsoft. Also, test 8pre on other system to verify functionality)
ANTEC who built this machine swears that because it's service pak3 you can't change the sidspeed value anyway. But they were not much help either. The popping and dropouts are getting worse too.It's clear that there is a Firewire communication problem on this system. What's unclear is whether the OS is problematic or if the Firewire adapter is malfunctioning. I usually consider an OS install as a last resort.
Sound familiar to anybody out there?
