upgrade to 10.6 if 10.5.8 working well??
charlesparente
Post by charlesparente »
Now that SL has had it's fourth update, I'm thinking more about taking the plunge. That's what I usually do...wait 6-9 months or so after an OS release.
If I was having problems, I'd be quick to try 10.6 to see if that provided improvements, but currently I have zero problems with my setup now using 10.5.8.
All of my hardware and software and VIs work great.
DP rocks, as usual.
So I'm searching for opinions here---is 'better' the enemy of 'good'?
Is DP performance even better in SL than in 10.5.8?
My gut feeling is to not upgrade until some software or VI that I use/want
requires 10.6.
Thanks,
Charles
Charles
http://www.dptips.net [...my very humble tribute to DP]
DP 8-latest version, Mac OS 10.9.4, MacMini 2012, 16GB RAM, Metric Halo ULN-2d, MOTU Micro-Lite usb MIDI interface, Vienna SE, VE Pro, Kontakt latest version, many Kontakt VIs and libraries.
Frodo
Re: upgrade to 10.6 if 10.5.8 working well??
Post by Frodo »
charlesparente wrote:... but currently I have zero problems with my setup now using 10.5.8.
DP rocks, as usual
You know, having zero problems is a good thing. It's so good that I would be reluctant to change anything.
If you wanted to try out Snow Leopard, it might be safer to install it on a separate drive and then experiment a little with how your VIs and plugins get along, but for now I would leave your current setup intact.
Zero problems. Nice!! :P
