Recovering Files after Emptying the Trash
TheCoalman
Post by TheCoalman »
Does anyone know if you can recover a file or folder after it was emptied from the trash????
thanks
TheCoalman
G5 2.7 DP/10.4.11/3G RAM/DP 4.61/5.12/Mach 5 1.2/828/Express XT/UAD-1 4.2/Spectrasonics/EWSQ Gold/Sampletank 2.9
Re: Recovering Files after Emptying the Trash
thanks
Some disk utilities will do that (Norton used to but I stopped using in in OS 9). Maybe disk warrior does, and there is a shareware program that does it, but you have to activate and AFTER THAT you can recover files.
But a commercial prog. like Disk Warrior should do the trick. I don't know of any way to do it otherwise and it is not always 100%. It is VERY important to NOT write anything to the disk in question as you can overwrite the very data you want to recover.
Generally, you'll want to go with a solid commercial prog and steer away from shareware as it is going into your directory and messing with your HD...
TheCoalman
Thanks, I have both Disk Warrior and Data Rescue X but I cant find any info in either of the manuals for this specific problem....
TheCoalman
qo
Post by qo »
If you have Data Rescue X, read this:
http://www.thexlab.com/faqs/datarecovery.html
But, realize that OSX is constantly writing to the system disk. So, even if you haven't written anything to the disk yourself, your files could still be history.
midiw
Post by midiw »
DiskWarrior JUST repairs the OS X directories.
It is just a one trick pony!
Mac OS: Mojave
