Instrument won't open after DP7 upgrade
Graywolf
Post by Graywolf »
I upgraded from DP4.61 to 7.12 and now my East West Boesendorfer 290 won't open. The window opens but it's just a white square. No problem with any other instruments or plugins and it does open as a stand alone.
rodger1811
Re: Instrument won't open after DP7 upgrade
Post by rodger1811 »
Have you check to see if there are any updates for your instrument?
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
Graywolf
Post by Graywolf »
No updates, have the latest version.
27" iMac 2.8GHz Quad Core i5• 32 GB RAM • 1 TB SSD • OS 10.13.6
MacBook Pro 2.9GHz i5 • 8GB RAM • 500GB SSD • OS 12.7.2
MOTU 896mk3h
DP 9.52
kassonica
Post by kassonica »
Maybe uninstall it (the VI) and reinstall it and see if that helps.
NazRat
Post by NazRat »
I'm going to guess that you're still on PPC since you were at 4.xx. So, if it's the old Kompakt Player version, then those VI's have been broken since somewhere in the DP 6.x release. NI doesn't support them and neither does East West. I've been using my old EWQLSO in Kontakt 3.5 rather than updating to the Play version. If you log into your NI account, there should be a free Kontakt Player 3.5 listed under legacy products - try that. You'll have to reauthorize the EW samples through the NI Service Center app.
DP8.06 PT11.2.0 VEP 5.3.x
Graywolf
Post by Graywolf »
Yes, that's what I was trying to avoid. I'm getting a new computer in a couple of months so I think I'll wait till then and reinstall.
Here's some additional info. It will open in Kontakt 3 but I can only load presets, no editng paramaters.
And if I open an older sequence that had the Bos. 290 saved in it, it will play but the instrument window is still blank.
MOTU 896mk3h
DP 9.52
Graywolf
Post by Graywolf »
Nazrat
just saw your post. Thanks
MOTU 896mk3h
DP 9.52
