"Attach MIDI Device" How to Save???
albusark
Post by albusark »
I use a Korg NanoKontrol to adjust faders, fx, transport, etc. in DP 7.12. Now in any given project, I assign a dozen or more controls in the mixer with the "Attach MIDI Controller" feature, and it all stays assigned until I save and quit. Transport control always works because it's set up in the Commands menu, but when I load up a project the fader assignments and such are not there. Is there a way to make sure these get saved? It's quite a hassle to go through reassigning them, especially since there isn't a hotkey for that particular menu feature. :?
Twitch_12
Re: "Attach MIDI Device" How to Save???
Post by Twitch_12 »
The MIDI controls always stay active for me even after save (DP 7.12). I usually have the controls already assigned in my template and when I load it, my control surface is able to control whatever I have setup.
I gave up using DP's control surface integration a long time ago and prefer to use my own custom setup. I just wish there was a way to automate mutes.... it's really surprising this feature doesn't exist.
DP7.24, DP 8, MBP 8 core 2.3Ghz i7, 8GB Ram, 750GB 7200RPM Internal SSD Hybrid, OS 10.6.8. MOTU Ultralite FW 1.15 / Driver 1.6.54199
albusark
Post by albusark »
"I usually have the controls already assigned in my template and when I load it, my control surface is able to control whatever I have setup."
Thank you that's exactly what needed to happen. Your reply is much appreciated. Big up the MOTU Nation.
