DP 6.03 ( and 7.12 ) crashes after 4/5 hrs of work.
sestopiano
Post by sestopiano »
Hi all,
Sorry for my english, but i'm in a real trouble casue i had to finish a work and i need an help.
I thought was autotune but after days of try i have always the same problem even without autotune installed.
After 4 or 5 hours of regulary work my DP 6.03 ( or 7.12 ) crashes.
I try also songs with few tracks, no plugin, no other pcie installed ( i have a UAD-2 and a firewire pcie expansion ).
I tried reformatting and reinstalling osx ( 10.5.8 ) and DP without installing anything else on different hardisks ( WD 1000gb, seagate 750 gb, maxtor 250g ) and starting from internal or external boxes, it still crash...
i changed firewire cables and ports, it still crash.
The strange thing i noticed that only for a second after pressing play, the playback meter on audio performance windows goes to red, and when perfomer starting crashes the playback meter remeains on red for 1 minute, the button play remains on, the audio disappear, and after 1 or 2 minutes the total crash.
PowerPC G5 Dual 2 GHz, 4.5 ddr2, 750gb sata disk, DP 6.03 and DP 7.12 ( 1024 buffer size, medium priority) , Apogee ensemble, OSX 10.5.8, UAD-2.
spencer4t
Re: DP 6.03 crashes after 4/5 hours of work.
Post by spencer4t »
Interesting post....I have had this problem as well. I've never timed it but I have noticed that if I get a few hours into a project it has a tendency to crash. It doesn't happen all the time, and it seems like it happens more when I am working with MIDI files that I download off the internet and am in the process of editing. I am also running 6.03 as well. Frustrating.
DP 6.02 & 6.03
imac 2.8GHz Quad-Core Intel Core i7 8 gig RAM
Macbook 2.4 GHz Intel Core 2 Duo 4 gig RAM
Plugins - Superior Dummer 2.0 / Machfive 2.0 / BPM / Electric Keys / Symphonic Instrument / Kontakt Sounds / Ozone 4 / Wavearts plugins (masterverb, multidynamics, trackplug) / Yamaha Motif XS6 / Yamaha Motif ES7
My Two Bands
http://www.formerlythree.com
http://www.theinnocencelive.com
Dan Worley
Post by Dan Worley »
Maybe look in the crash log and send it to MOTU, or post it up here so someone who knows how to decipher it can tell you what might be causing the problem.
/Library/Logs/CrashReporter
c-ya,
Dan Worley
DP10.13
newrigel
Post by newrigel »
Dan Worley wrote:Maybe look in the crash log and send it to MOTU, or post it up here so someone who knows how to decipher it can tell you what might be causing the problem.
c-ya,
Dan Worley
+1 :mrgreen:
sestopiano
maybe i got solution, maybe..., the problem seems to be in 2 programs that take 30/50 % of cpu even when restart and no program is running, the famous "spotlight" and most of all "mds". This last one sometimes is a cpu killer...
If you launch "acitivity monitoring" in utlity folder ( quit all programs before ) you can check your cpu state. If the cpu is working at 30/50 you have the same problem as me.
Now, when you launch performer, even the cpu meter in "audio performance" window is about 10%, the cpu ( the real cpu state) in "activity monitoring" program goes up more of 60% and this is normal for my old G5 dual 2ghz
The result ( mds and performer ) is a 100% of cpu stress while a simple performer song of 8 tracks and no plugins is playng. Next result, crash....
I killed forever mds and spotlight with a certain procedure on terminal and after 12 hours of work performer 7.12 doesnt crash for the first time in 2 weeks of nightmare tries...
I want to do other tests to be sure about it, and after i will write the exactly procedure.
Mario
labman
Post by labman »
sestopiano wrote:maybe i got solution, maybe..., the problem seems to be in 2 programs that take 30/50 % of cpu even when restart and no program is running, the famous "spotlight" and most of all "mds". This last one sometimes is a cpu killer...
Mario
What is 'mds'?
sestopiano
Re: DP 6.03 ( and 7.12 ) crashes after 4/5 hours of work.
It's the spotlight indexing process
http://blog.expandrive.com/2007/06/24/i ... -spotless/" onclick="window.open(this.href);return false;
Right. So fault is Spotlight, not DP?
sestopiano
Re: DP 6.03 ( and 7.12 ) crashes after 4/5 hrs of work. RESO
Yes Mr James, the fault is Spotlight, since i kill it ( i had to write something about mds too in terminal but dont ask me why...:) it works and this is good!!
i opened terminal and copy and paste:
id
ls -l /private/var/tmp/mds
ls -l /private/var/tmp/mds/$(id -u)
echo "done"
and then copy and paste this:
sudo chmod 0 /System/Library/CoreServices/Spotlight.app
and after copy and paste this:
killall Spotlight
it worked for me!
sestopiano
After 12 hours of work it crashed!!!! I cant believe it
this is the log
Process: Digital Performer [139]
Path: /Applications/Digital Performer 6.03.app/Contents/MacOS/Digital Performer
Identifier: com.motu.DigitalPerformer
Version: 6.03 (6.03)
Code Type: PPC (Native)
Parent Process: launchd [83]
Interval Since Last Report: 126570 sec
Crashes Since Last Report: 1
Per-App Interval Since Last Report: 51464 sec
Per-App Crashes Since Last Report: 1
Date/Time: 2010-05-15 10:52:23.797 +0200
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: E11880EF-4ED3-4BA0-B9CA-7C2C9C209BA4
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000005
Crashed Thread: 0
Thread 0 Crashed:
0 com.apple.CoreFoundation 0x95ea141c CFRelease + 240
1 com.apple.CoreGraphics 0x91e422d8 CGSDecodeEventRecord + 156
2 com.apple.CoreGraphics 0x91e41934 snarfEvents + 288
3 com.apple.CoreGraphics 0x920a6830 CGSGetNextEventRecordInternal + 148
4 com.apple.CoreGraphics 0x91e41770 CGEventCreateNextEvent + 24
5 com.apple.HIToolbox 0x95f85404 PullEventsFromWindowServerOnConnection(unsigned int, unsigned char) + 84
6 com.apple.CoreFoundation 0x95e7d268 __CFMachPortPerform + 180
7 com.apple.CoreFoundation 0x95e9f630 CFRunLoopRunSpecific + 2480
8 com.apple.HIToolbox 0x95facb14 RunCurrentEventLoopInMode + 264
9 com.apple.HIToolbox 0x95fac8a0 ReceiveNextEventCommon + 260
10 com.apple.HIToolbox 0x9600a9d4 RunApplicationEventLoop + 148
11 com.motu.DigitalPerformer 0x0062e264 0x1000 + 6476388
12 com.motu.DigitalPerformer 0x00003bf8 0x1000 + 11256
13 com.motu.DigitalPerformer 0x000038fc 0x1000 + 10492
14 ??? 0xbffffbb8 0 + 3221224376
Thread 1:
0 libSystem.B.dylib 0x97006358 mach_wait_until + 8
1 libSystem.B.dylib 0x970916ec nanosleep + 324
2 libSystem.B.dylib 0x97091594 usleep + 68
3 PerfMSL.dylib 0x023c8b78 PerfAssert::SetEnableDebugMsgs(bool) + 6272
4 PerfMSL.dylib 0x023c8770 PerfAssert::SetEnableDebugMsgs(bool) + 5240
5 libSystem.B.dylib 0x970480d0 _pthread_start + 316
Thread 2:
0 libSystem.B.dylib 0x970061d8 mach_msg_trap + 8
1 libSystem.B.dylib 0x9700d0fc mach_msg + 56
2 PerfFoundation.dylib 0x0222d9a8 PerfWorkerThread::GetThread() + 916
3 PerfFoundation.dylib 0x0222da9c PerfWorkerThread::GetThread() + 1160
4 libSystem.B.dylib 0x970480d0 _pthread_start + 316
Thread 3:
0 libSystem.B.dylib 0x97006248 semaphore_timedwait_trap + 8
1 AllUtilities.dylib 0x00fd34a0 PerfSemaphore::timed_wait(long) + 96
2 PerfEngine.dylib 0x01cee908 PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 836
3 PerfEngine.dylib 0x01cee954 PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 912
Thread 4:
2 com.apple.audio.MIDI.CoreMIDI 0x00fa7f34 XServerMachPort::ReceiveMessage(int&, void*, int&) + 88
3 com.apple.audio.MIDI.CoreMIDI 0x00f99adc MIDIInPortThread::Run() + 68
4 com.apple.audio.MIDI.CoreMIDI 0x00f9d104 XThread::RunHelper(void*) + 24
5 com.apple.audio.MIDI.CoreMIDI 0x00fa8aa8 CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x970480d0 _pthread_start + 316
Thread 5:
2 com.apple.CoreFoundation 0x95e9f394 CFRunLoopRunSpecific + 1812
3 com.apple.audio.CoreAudio 0x96495fa8 HALRunLoop::OwnThread(void*) + 212
4 com.apple.audio.CoreAudio 0x96495de4 CAPThread::Entry(CAPThread*) + 104
Thread 6:
2 com.motu.MAS.framework 0x017e31d0 0x1794000 + 324048
Thread 7:
0 libSystem.B.dylib 0x97006228 semaphore_wait_trap + 8
1 com.motu.MAS.framework 0x017a0510 0x1794000 + 50448
2 com.motu.MAS.framework 0x017e27c0 0x1794000 + 321472
3 libSystem.B.dylib 0x970480d0 _pthread_start + 316
Thread 8:
1 PerfEngine.dylib 0x01a9200c TrackGroupManager::TrackGroupManager() + 1712
Thread 9:
Thread 10:
0 libSystem.B.dylib 0x9700cbec __semwait_signal + 12
1 libSystem.B.dylib 0x97049478 _pthread_cond_wait + 1580
2 com.apogee.EnsemblePlugIn 0x1e13472c apogeeDriverPlugInMessageQueue::WaitForNextMessageInList() + 68
3 com.apogee.EnsemblePlugIn 0x1e135774 ClientBiDirConnection::HandlePropertyChanges() + 40
4 com.apogee.EnsemblePlugIn 0x1e135e38 PthreadHandlingPropertyChanges(void*) + 48
Thread 11:
2 com.apogee.EnsemblePlugIn 0x1e132c34 MessageTX::TXThread() + 76
3 com.apogee.EnsemblePlugIn 0x1e133ac4 TransmitThread(void*) + 48
Thread 12:
0 libSystem.B.dylib 0x97069db4 recvfrom$UNIX2003 + 12
1 com.apogee.EnsemblePlugIn 0x1e1368a0 ClientBiDirLocalSocketConnection::ReceiveData(void*, int) + 104
2 com.apogee.EnsemblePlugIn 0x1e131f00 MessageRX::RXThread() + 248
3 com.apogee.EnsemblePlugIn 0x1e13284c ReceiveThread(void*) + 48
Thread 13:
1 com.motu.MAS.framework 0x0182b7b4 0x1794000 + 620468
Thread 14:
Thread 15:
0 libSystem.B.dylib 0x97006258 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x97049374 _pthread_cond_wait + 1320
2 com.apple.audio.CoreAudio 0x964a79f0 HP_IOThread::WorkLoop() + 488
3 com.apple.audio.CoreAudio 0x964a77f0 HP_IOThread::ThreadEntry(HP_IOThread*) + 12
Thread 16:
2 PerfFoundation.dylib 0x0223029c GetUnitTestRandomLong() + 108
Thread 17:
Thread 18:
2 ...ple.CoreServices.CarbonCore 0x94bb19e4 TSWaitOnConditionTimedRelative + 240
3 ...ple.CoreServices.CarbonCore 0x94bb17b8 TSWaitOnSemaphoreCommon + 428
4 ...ple.CoreServices.CarbonCore 0x94bb147c AsyncFileThread(void*) + 64
Thread 0 crashed with PPC Thread State 32:
srr0: 0x95ea141c srr1: 0x0000d030 dar: 0x00000005 dsisr: 0x40000000
r0: 0x00000000 r1: 0xbfffa8c0 r2: 0xa0841334 r3: 0x00000000
r4: 0x00000000 r5: 0x00000000 r6: 0x0000002c r7: 0x00000e03
r8: 0x00000000 r9: 0x00000000 r10: 0x97131eb8 r11: 0xa02a3f70
r12: 0x95ea132c r13: 0x00000000 r14: 0xa083c478 r15: 0x00000000
r16: 0x00000000 r17: 0x00000001 r18: 0x00000000 r19: 0x00000000
r20: 0x00000000 r21: 0xa083c478 r22: 0xbfffed18 r23: 0x92371dc8
r24: 0xbfffa9b4 r25: 0xbfffa9b8 r26: 0x028254d0 r27: 0x91e44348
r28: 0x000003e8 r29: 0x00000000 r30: 0x00000000 r31: 0x95ea1334
cr: 0x24042422 xer: 0x20000000 lr: 0x95ea1334 ctr: 0x95ea132c
vrsave: 0x00000000
Binary Images:
0x1000 - 0xb54fe7 +com.motu.DigitalPerformer 6.03 (6.03) <191abf19a1ff49bba10df6afdd126c9e> /Applications/Digital Performer 6.03.app/Contents/MacOS/Digital Performer
0xf96000 - 0xfb2ffb com.apple.audio.MIDI.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xfc8000 - 0xfe3fef +AllUtilities.dylib ??? (???) <4b2d9feb3d744825a8d799316fd68216> /Applications/Digital Performer 6.03.app/Contents/MacOS/AllUtilities.dylib
0xff7000 - 0x103efc3 +DPBasicUI.dylib ??? (???) <e6caa4a25c13452b8994b10aff1bdb11> /Applications/Digital Performer 6.03.app/Contents/MacOS/DPBasicUI.dylib
0x106d000 - 0x12f5ffb +DPPart2.dylib ??? (???) <b698973999fe4bf28429b560d7e7f149> /Applications/Digital Performer 6.03.app/Contents/MacOS/DPPart2.dylib
0x14e9000 - 0x14f4feb +FileSystem.dylib ??? (???) <03122bb4d6a746ac91034167edd5401a> /Applications/Digital Performer 6.03.app/Contents/MacOS/FileSystem.dylib
0x1500000 - 0x1552fdb +GenericPanes.dylib ??? (???) <bc375b5f4e4c48928ad4cfd37d16830f> /Applications/Digital Performer 6.03.app/Contents/MacOS/GenericPanes.dylib
0x15af000 - 0x1624fc7 +HiLevelWrappers.dylib ??? (???) <0bd3c284bab94ed18c6f236a4deea1c9> /Applications/Digital Performer 6.03.app/Contents/MacOS/HiLevelWrappers.dylib
0x1653000 - 0x174afff +com.motu.MidiSystem MidiSystem version 1.0 (1.0) <dc668d80e3f44e52bdd45d2bb6218707> /Applications/Digital Performer 6.03.app/Contents/Frameworks/MidiSystem.framework/Versions/A/MidiSystem
0x178f000 - 0x1791fd7 +com.motu.MPO.framework MotuPublicObjects 3.1 (3.1) <8b428b7f7c614daeb50aa2d32e1ee14f> /Applications/Digital Performer 6.03.app/Contents/Frameworks/MotuPublicObjects.framework/Versions/A/MotuPublicObjects
0x1794000 - 0x1849ffb +com.motu.MAS.framework 4.0.0 (4.0.0) <4a88c9d68cd74f38a4815f2320722a04> /Applications/Digital Performer 6.03.app/Contents/Frameworks/MotuAudioSystem.framework/Versions/A/MotuAudioSystem
0x1869000 - 0x194afc7 +com.motu.DAE MotuDAE™ 1.0 (1.0) <82189f7375f64d059373067a3abcba08> /Applications/Digital Performer 6.03.app/Contents/Frameworks/MotuDAE.framework/Versions/A/MotuDAE
0x1988000 - 0x1a44fdf +OMF_AAF.dylib ??? (???) <853ef75409104de3bb59a13b7fc0421c> /Applications/Digital Performer 6.03.app/Contents/MacOS/OMF_AAF.dylib
0x1a5e000 - 0x1f89fef +PerfEngine.dylib ??? (???) <04c49e3fdeef46738e15ba0a43ea5350> /Applications/Digital Performer 6.03.app/Contents/MacOS/PerfEngine.dylib
0x21cf000 - 0x21d4fe7 +PerfError.dylib ??? (???) <e15ac86e3d244a3b82030032a64bb214> /Applications/Digital Performer 6.03.app/Contents/MacOS/PerfError.dylib
0x21da000 - 0x231bff7 +PerfFoundation.dylib ??? (???) <2998c7812e73475ba21c04623ac0fee3> /Applications/Digital Performer 6.03.app/Contents/MacOS/PerfFoundation.dylib
0x23c3000 - 0x23cdfdf +PerfMSL.dylib ??? (???) <62fb85ebb77a4f76b5a9b9defbbea5f7> /Applications/Digital Performer 6.03.app/Contents/MacOS/PerfMSL.dylib
0x23d7000 - 0x249dff7 +PureDSP.dylib ??? (???) <b2d6b65b79bb4680a5e730da5b600d0c> /Applications/Digital Performer 6.03.app/Contents/MacOS/PureDSP.dylib
0x24e0000 - 0x24e3fcf +ResourceAccess.dylib ??? (???) <37bd605c90744053a8c244951b651494> /Applications/Digital Performer 6.03.app/Contents/MacOS/ResourceAccess.dylib
0x24e8000 - 0x24feff3 +XML.dylib ??? (???) <ad6dc00dc2fd4a3d94f1c8601f174cec> /Applications/Digital Performer 6.03.app/Contents/MacOS/XML.dylib
0x250c000 - 0x252affb +PerfOSInterface.dylib ??? (???) <4b70687f0d0c4daba844a53597fc4ccb> /Applications/Digital Performer 6.03.app/Contents/MacOS/PerfOSInterface.dylib
0x253b000 - 0x255cff1 libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
0x2564000 - 0x2585fff libexpat.1.dylib ??? (???) <e955fbf7296287c4d40694cf7dffd64f> /usr/lib/libexpat.1.dylib
0x258c000 - 0x265aff5 com.apple.DiscRecording 4.0.7 (4070.4.1) <73f6a269ffb9718fa9f165da9f2a5eb1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x26c1000 - 0x26ebffb com.apple.DiscRecordingUI 4.0.7 (4070.4.1) <37cb0b8d9ad4e211a9b075ae9a92ed74> /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
0x27f6000 - 0x27f8ffd com.apple.textencoding.unicode 2.2 (2.2) <483d06bdf16bdbbad53efcea4fcfb688> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x82c7000 - 0x82d0fff +com.uaudio.UAD Precision De-Esser 5.6.0 (5.6.0) <cfa4ac726611180a394efa4814c57e28> /Library/Audio/Plug-Ins/Components/UAD Precision De-Esser.component/Contents/Resources/UAD Precision De-Esser.vst/Contents/MacOS/UAD Precision De-Esser
0x86dd000 - 0x86effc7 +com.MOTU.plugin.AudioExport.CoreAudio 1.5.1 (1.0) <4650236e702642b4a7f8ebe1f6452c10> /Library/Audio/Plug-Ins/MOTU Audio Export/Core Audio Export.bundle/Contents/MacOS/Core Audio Export
0x8702000 - 0x8709fe9 +com.MOTU.plugin.AudioExport.LAME 1.2.1 (1.0) <17c2f1eaab7747978f04ee52fffd4c75> /Library/Audio/Plug-Ins/MOTU Audio Export/LAME Audio Export.bundle/Contents/MacOS/LAME Audio Export
0x8711000 - 0x8727fef +com.MOTU.plugin.AudioExport.QT 2.6 (1.0) <c2fbaa72d6464ef0aee91a7929f71a02> /Library/Audio/Plug-Ins/MOTU Audio Export/QuickTime Export.bundle/Contents/MacOS/QuickTime Export
0x8795000 - 0x880efe3 +com.DivXInc.DivXDecoder 6.0.5 (6.0.5) /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
0x881f000 - 0x8a0bff3 com.apple.audio.codecs.Components 1.9.1 (1.9.1) /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x8b02000 - 0x8b03ffd com.apple.aoa.halplugin 2.5.8 (2.5.8f1) <0d6be2c83d2f582060ba48293d283cdd> /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x8b3a000 - 0x8b65ffb com.apple.audio.SoundManager.Components 3.9.3 (3.9.3) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x8b6b000 - 0x8b6ffff com.apple.audio.AudioIPCPlugIn 1.0.6 (1.0.6) <ac58ebbd8e1179ff891b7a60b2ba33cc> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x8b74000 - 0x8bb2ff7 com.apple.QuickTimeFireWireDV.component 7.6.6 (1674) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x8bc9000 - 0x8bcaffb ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x8f67000 - 0x9159ffe +com.MOTU.MAS.plugin.ArcPan 2.4.4 (2.4.4) <a0f202e8a69c4d70969d4b748b55d370> /Library/Audio/Plug-Ins/MAS/Arc Panner.bundle/Contents/MacOS/Arc Panner
0x9233000 - 0x9457fcf +com.MOTU.MAS.plugin.Auralizer 2.4.4 (2.4.4) <5889a8956ed84989b5b5547b4678a516> /Library/Audio/Plug-Ins/MAS/Auralizer.bundle/Contents/MacOS/Auralizer
0x9513000 - 0x9687ffe +com.MOTU.MAS.plugin.AutoPan 4.3.2 (4.3.2) <1c18643afdb74351b807a1ff75fba04f> /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
0x97c0000 - 0x97caff7 +com.MOTU.MAS.plugin.InvertPhase 1.1.1 (1.0) <946d199040ae47d3b9de0bf2bf51ea64> /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
0x97e4000 - 0x9933fc6 +com.MOTU.MAS.plugin.BassManager 2.3.3 (2.3.3) <b4436378458842899246a2f96971112c> /Library/Audio/Plug-Ins/MAS/Bass Manager.bundle/Contents/MacOS/Bass Manager
0x9982000 - 0x9c5cfff +com.motu.mas.plugin.BassLine 1.2.4 (1.2.4) <88c1573de07f4b25963ef095929b8d66> /Library/Audio/Plug-Ins/MAS/BassLine.bundle/Contents/MacOS/BassLine
0x9cce000 - 0x9dceff7 +com.MOTU.MAS.plugin.Buffy 2.4.2 (2.4.2) <4099ce1c22224f14891e71ef35495dc9> /Library/Audio/Plug-Ins/MAS/Buffy.bundle/Contents/MacOS/Buffy
0x9e0a000 - 0x9f93fce +com.MOTU.MAS.plugin.Calibration 2.3.3 (2.3.3) <41735a2488184de6bbd4eaf9464ff10d> /Library/Audio/Plug-Ins/MAS/Calibration.bundle/Contents/MacOS/Calibration
0x9feb000 - 0xa13bfde +com.MOTU.MAS.plugin.Chorus 3.3.2 (3.3.2) <e4630779a6d74469a5c6d411db5a3d81> /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
0xa18b000 - 0xa273fee +com.MOTU.MAS.plugin.DCNotch 4.3.2 (4.3.2) <bde805236d3c46f58d5193f90b34f0d5> /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
0xa2a6000 - 0xa4cfffe +com.MOTU.MAS.plugin.Delay 3.3.5 (3.3.5) <faf2a6916b094a2f8d8b5ea42e943f88> /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
0xa54d000 - 0xa6c3fe2 +com.MOTU.MAS.plugin.Dynamics 3.4.1 (3.4.1) <920ced38ff39431fbc8ab7d37a283c51> /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
0xa719000 - 0xa86ffd2 +com.MOTU.MAS.plugin.Echo 3.3.2 (3.3.2) <7357858550694be18287d1db06facddc> /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
0xa8c2000 - 0xaab8ff6 +com.MOTU.MAS.plugin.eVerb 4.4.2 (4.4.2) <a3f2a85e25e4459ba0bbe6d4ef447670> /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
0xab1e000 - 0xac84fde +com.MOTU.MAS.plugin.Flanger 4.3.2 (4.3.2) <f338f258b5384082a662b3e1f7fd808b> /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
0xacd9000 - 0xad52ffb +com.MOTU.MAS.AudioUnitSupport 1.7.0 (1.0) <25e86c5463cc43ec9174192aec6c5ddd> /Library/Audio/Plug-Ins/MAS/MAS AudioUnit Support.bundle/Contents/MacOS/MAS AudioUnit Support
0xae0e000 - 0xaf92fe6 +com.MOTU.MAS.plugin.MWCompressor 3.5.2 (3.5.2) <bc311c3998a8477cae6068254ff45f4a> /Library/Audio/Plug-Ins/MAS/MasterWorks Compressor.bundle/Contents/MacOS/MasterWorks Compressor
0xb026000 - 0xb236fe6 +com.MOTU.MAS.plugin.MWEQ 1.4.1 (1.4.1) <1d3b8ff3b2de427b846536cff2609618> /Library/Audio/Plug-Ins/MAS/MasterWorks EQ.bundle/Contents/MacOS/MasterWorks EQ
0xb2a2000 - 0xb439fe7 +com.MOTU.MAS.plugin.MWGate 2.5.1 (2.5.1) <7696c2a7c19d497bba896d9a88c870ef> /Library/Audio/Plug-Ins/MAS/MasterWorks Gate.bundle/Contents/MacOS/MasterWorks Gate
0xb4be000 - 0xb60dff2 +com.MOTU.MAS.plugin.MWLeveler 1.5.1 (1.5.1) <0b19cc847b0e497897ce19b5565d483e> /Library/Audio/Plug-Ins/MAS/MasterWorks Leveler.bundle/Contents/MacOS/MasterWorks Leveler
0xb657000 - 0xb854fe6 +com.MOTU.MAS.plugin.MWLimiter 4.4.1 (4.4.1) <c92591fbd90e46039f4374fd232ca979> /Library/Audio/Plug-Ins/MAS/MasterWorks Limiter.bundle/Contents/MacOS/MasterWorks Limiter
0xb8cd000 - 0xbe00ff7 +com.MOTU.MAS.plugin.Model12 1.2.4 (1.2.4) <f3227f81f3cc466c9d09428b27b71aa6> /Library/Audio/Plug-Ins/MAS/Model12.bundle/Contents/MacOS/Model12
0xbf32000 - 0xc46e047 +com.motu.mas.plugin.modulo 1.2.4 (1.2.4) <8eb6a27523104851a4c71e827a7d26c2> /Library/Audio/Plug-Ins/MAS/Modulo.bundle/Contents/MacOS/Modulo
0xc700000 - 0xc807fd6 +com.MOTU.MAS.plugin.MSDecoder 2.3.2 (2.3.2) <a7c1d2da1683451db941a81301baafe7> /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
0xc87b000 - 0xca24fe2 +com.MOTU.MAS.plugin.MultiModeFilter 2.4.1 (2.4.1) <8814228143cb4238a8871018dd437890> /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
0xca8a000 - 0xcc6bffe +com.MOTU.MAS.plugin.MultiPan 2.4.4 (2.4.4) <37ecc291b2c544478eb5ed3ba586fbc7> /Library/Audio/Plug-Ins/MAS/n-Panner.bundle/Contents/MacOS/n-Panner
0xcced000 - 0xd1ecfef +com.motu.mas.plugin.nanosampler 1.2.4 (1.2.4) <fe9fa28f50c443a78b37b51e3e3539c3> /Library/Audio/Plug-Ins/MAS/nanosampler.bundle/Contents/MacOS/nanosampler
0xd2f6000 - 0xd4fafce +com.MOTU.MAS.plugin.ParaEQ 4.4.1 (4.4.1) <e18718212144405085a2159d053f0cb0> /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
0xd5a7000 - 0xd71bffe +com.MOTU.MAS.plugin.PatternGate 1.2.3 (1.2.3) <0eac81435e314a86901ce935f0a411dd> /Library/Audio/Plug-Ins/MAS/PatternGate.bundle/Contents/MacOS/PatternGate
0xd7c1000 - 0xd91effe +com.MOTU.MAS.plugin.Phaser 4.3.2 (4.3.2) <c52a55816c9b4c469c29e773724031b7> /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
0xd99c000 - 0xdb21fd2 +com.MOTU.MAS.plugin.Plate 2.3.2 (2.3.2) <08c25f8eaffb49d3bd8e876f945036e7> /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
0xdb83000 - 0xde84fef +com.motu.mas.plugin.PolySynth 1.2.4 (1.2.4) <1c02379874b945a5830d962fabb751f5> /Library/Audio/Plug-Ins/MAS/PolySynth.bundle/Contents/MacOS/PolySynth
0xdf00000 - 0xe07bfe7 +com.MOTU.MAS.plugin.Preamp 3.3.2 (3.3.2) <97c799f4133f4b62a7cf55457e643eda> /Library/Audio/Plug-Ins/MAS/Preamp-1.bundle/Contents/MacOS/Preamp-1
0xe0fe000 - 0xe51efe7 +com.motu.mas.plugin.proton 1.2.4 (1.2.4) <95a012dae84041429794425fbd0d891e> /Library/Audio/Plug-Ins/MAS/Proton.bundle/Contents/MacOS/Proton
0xe5c2000 - 0xebb4ff7 +com.MOTU.MAS.plugin.ProVerb 1.1.5 (1.1.5) <3336c01764934399a37c84a218d53545> /Library/Audio/Plug-Ins/MAS/ProVerb.bundle/Contents/MacOS/ProVerb
0xedb7000 - 0xeecaffe +com.MOTU.MAS.plugin.QuanJr 2.3.2 (2.3.2) <b35a774a1efa4736a1be58003d782fa5> /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
0xef14000 - 0xef18ff7 +com.MOTU.MAS.plugin.Reverse 1.1.1 (1.0) <cae1e9dea62649cbb5428b85511f3ab8> /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
0xef41000 - 0xf04cfda +com.MOTU.MAS.plugin.Reverb 3.3.2 (3.3.2) <999517b96afa4f12ac6e04c380aff2af> /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
0xf087000 - 0xf1e6ffa +com.MOTU.MAS.plugin.RingMod 2.4.1 (2.4.1) <1f903466789b4c7c9b3c8ccdf3071b4e> /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
0xf253000 - 0xf423fe7 +com.MOTU.MAS.plugin.SonicModulator 3.3.2 (3.3.2) <8565bfddbbc34d70b272ec3fabca239a> /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
0xf496000 - 0xf5ecff6 +com.MOTU.MAS.plugin.Tremolo 4.3.2 (4.3.2) <2c9eb79df95d4149bb2474f9cd5c8df3> /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
0xf64c000 - 0xf7baff6 +com.MOTU.MAS.plugin.Trigger 2.3.4 (2.3.4) <f59158402d94482189c33574f712580a> /Library/Audio/Plug-Ins/MAS/Trigger.bundle/Contents/MacOS/Trigger
0xf80f000 - 0xf97dff6 +com.MOTU.MAS.plugin.Trim 4.3.3 (4.3.3) <3b84f7a2d6124a4bb05b5f4690927965> /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
0xf9d9000 - 0xfbd3ffb +com.MOTU.MAS.plugin.TriPan 2.4.4 (2.4.4) <646c1f6bc5b744e193881a879ba18cbd> /Library/Audio/Plug-Ins/MAS/TriPan.bundle/Contents/MacOS/TriPan
0xfd84000 - 0xfd94ffb +com.uaudio.UAD2_Plugin_Support 5.6.0 (5.6.0) <f9cd89838e033d9165ecfe6234f8a8c1> /Library/Frameworks/UAD-2 Plugin Support.framework/Versions/A/UAD-2 Plugin Support
0xff25000 - 0xff37ffd libTraditionalChineseConverter.dylib ??? (???) <07753e0608a196a757730e6d8e41c6d5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0xff3b000 - 0xff4affe libSimplifiedChineseConverter.dylib ??? (???) <5d2c02469922e44114f56621e8e8545e> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x110f2000 - 0x1111dfeb +com.MOTU.plugin.ControlSurface.HUI 1.2.2 (1.0) <a4ed8f95f6a942b2bed40c3761d3dab9> /Library/Audio/Plug-Ins/MOTU Control Surface/HUI.bundle/Contents/MacOS/HUI
0x1113d000 - 0x1116dfff +com.MOTU.plugin.ControlSurface.MackieControl 1.2.2 (1.0) <e1de95501aa84958986d534c83f81bd9> /Library/Audio/Plug-Ins/MOTU Control Surface/MackieControl.bundle/Contents/MacOS/MackieControl
0x11191000 - 0x111c8fe7 +com.MOTU.plugin.ControlSurface.SAC_2_2 3.2.1 (1.0) <fd2a144af01841b18aa06e6134b71edb> /Library/Audio/Plug-Ins/MOTU Control Surface/SAC DP Driver.bundle/Contents/MacOS/SAC DP Driver
0x11883000 - 0x11a6aff3 com.apple.RawCamera.bundle 2.1.2 (517) <0e9f46b8ccedaf42500b75f0b16d856b> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x13a68000 - 0x13a8afff +com.uaudio.UAD Precision De-Esser 5.6.0 (5.6.0) <0eceb9391e84cb56cfff940b13dde014> /Library/Application Support/Universal Audio/UAD-2 Powered Plug-Ins/UAD Precision De-Esser.vst/Contents/MacOS/UAD Precision De-Esser
0x13ac9000 - 0x13ad2fff +com.uaudio.UAD Cambridge 5.6.0 (5.6.0) <2d1cbe21f00ae18ffd808d9c21d74216> /Library/Audio/Plug-Ins/Components/UAD Cambridge.component/Contents/Resources/UAD Cambridge.vst/Contents/MacOS/UAD Cambridge
0x1738e000 - 0x173b4ffb +com.uaudio.effects.UAD Precision De-Esser 5.6.0 (5.6.0) <73cf811cce6bc4cbb23394e66bc07211> /Library/Audio/Plug-Ins/Components/UAD Precision De-Esser.component/Contents/MacOS/UAD Precision De-Esser
0x17400000 - 0x17457fff +com.uaudio.UAD_GUI_Library 5.6.0 (5.6.0) <52ad12deb34a222687421dbfaff8b987> /Library/Frameworks/UAD GUI Library.framework/Versions/A/UAD GUI Library
0x17483000 - 0x174a6fff +com.uaudio.UAD Precision De-Esser 5.6.0 (5.6.0) <0b739e46d703d194279c626089dc781e> /Library/Application Support/Universal Audio/UAD-1 Powered Plug-Ins/UAD Precision De-Esser.vst/Contents/MacOS/UAD Precision De-Esser
0x1751b000 - 0x17524fff +com.uaudio.UAD LA2A 5.6.0 (5.6.0) <4a2a90b0b22c8e4fc46840a2cbe6ccf9> /Library/Audio/Plug-Ins/Components/UAD LA2A.component/Contents/Resources/UAD LA2A.vst/Contents/MacOS/UAD LA2A
0x17766000 - 0x1778cffb +com.uaudio.effects.UAD Cambridge 5.6.0 (5.6.0) <826989db02814913df60d2ca15c1bd91> /Library/Audio/Plug-Ins/Components/UAD Cambridge.component/Contents/MacOS/UAD Cambridge
0x17a3d000 - 0x17a6effb +com.uaudio.UAD Precision Equalizer 5.6.0 (5.6.0) <dc3eaae908499bc54120ce6800d49a7a> /Library/Application Support/Universal Audio/UAD-2 Powered Plug-Ins/UAD Precision Equalizer.vst/Contents/MacOS/UAD Precision Equalizer
0x17ad6000 - 0x17b13ffb +com.uaudio.UAD Cambridge 5.6.0 (5.6.0) <d9b06ff68b8748325bfa06b6917be8fd> /Library/Application Support/Universal Audio/UAD-2 Powered Plug-Ins/UAD Cambridge.vst/Contents/MacOS/UAD Cambridge
0x181f4000 - 0x18224fcb +com.Antares.musiceffects.AutoTuneAU_MM.component 5.1.0 (5.1.0) /Library/Audio/Plug-Ins/Components/AutoTuneAU_MM.component/Contents/MacOS/AutoTuneAU_MM
0x184b9000 - 0x1851bff7 +[Unknown Bundle] ??? (???) <4933962631074058a04b23db9ca66d94> [Unknown Bundle]
0x1864d000 - 0x18656fff com.apple.iokit.IOUSBLib 3.4.9 (3.4.9) <d8e92abec3e3d0569d298799e68bfbee> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x18778000 - 0x1879effb +com.uaudio.effects.UAD LA2A 5.6.0 (5.6.0) <33b52c2baa731b55e695374ec6306040> /Library/Audio/Plug-Ins/Components/UAD LA2A.component/Contents/MacOS/UAD LA2A
0x187dd000 - 0x1881eff3 +com.Antares.plugins.AutoTuneAU_MM 5.1.0 (5.1.0) <c37d67ef2bb2431ab28f73041ed36ae4> /Library/Audio/Plug-Ins/Components/AutoTuneAU_MM.component/Contents/Resources/AutoTuneAU_MM.bundle/Contents/MacOS/AutoTuneAU_MM
0x18a56000 - 0x18a77ffb +com.uaudio.UAD LA2A 5.6.0 (5.6.0) <2d973353b66b51591be4dd19fb984f0d> /Library/Application Support/Universal Audio/UAD-2 Powered Plug-Ins/UAD LA2A.vst/Contents/MacOS/UAD LA2A
0x1e119000 - 0x1e148fff com.apogee.EnsemblePlugIn 1.6.15 (1.6.15) <613b223af31de0c90ad5c4a3af9628ec> /System/Library/Extensions/EnsemblePlugIn.bundle/Contents/MacOS/EnsemblePlugIn
0x8fe00000 - 0x8fe30c23 dyld 97.1 (???) <89a0055b0e7ea2db881b73c6e63bc774> /usr/lib/dyld
0x90003000 - 0x90003fff com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90004000 - 0x905befff libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x905bf000 - 0x90704fff com.apple.QTKit 7.6.6 (1674) <44ef1bf932e0533429870509769f16e5> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x90705000 - 0x90705fff com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x90706000 - 0x9072efff libxslt.1.dylib ??? (???) <bb985380f353bbc7ce694d56884ea156> /usr/lib/libxslt.1.dylib
0x90735000 - 0x90a9affe com.apple.QuartzCore 1.5.8 (1.5.8) <60e54cfb861dc5e66bb4f263a192d558> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90a9b000 - 0x90ec9ffe libGLProgrammability.dylib ??? (???) <5d52750ec9e438b25d3a4db51361fa2b> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x90eca000 - 0x90f7dffc com.apple.CFNetwork 438.14 (438.14) <6e213ab40eabfc276ca46a7c7cfad01a> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90f7e000 - 0x91051fff com.apple.CoreServices.OSServices 228.1 (228.1) <2724e880900a223dfd47e08e1b52ed17> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9106f000 - 0x910befff libGLImage.dylib ??? (???) <2e1f2a2625064149d209ec19e52d0384> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x910bf000 - 0x910d7ffb com.apple.DictionaryServices 1.0.0 (1.0.0) <fe37191e732eeb66189185cd000a210b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x910d8000 - 0x910dfffb com.apple.print.framework.Print 218.0.3 (220.2) <021d2263007c538fd9e6b52e66a2623d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x910e0000 - 0x910ebffb libgcc_s.1.dylib ??? (???) <ea47fd375407f162c76d14d64ba246cd> /usr/lib/libgcc_s.1.dylib
0x910ec000 - 0x91862fff com.apple.AppKit 6.5.9 (949.54) <687f1742c249d7c9268e2eb57713cef6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x919d0000 - 0x91ac6ffc libiconv.2.dylib ??? (???) <05ae1fcc97404173b2f9caef8f8be797> /usr/lib/libiconv.2.dylib
0x91ac7000 - 0x91b42fff com.apple.SearchKit 1.2.2 (1.2.2) <a9d0033a5e1e55b5e382e52fe578d734> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91b43000 - 0x91b50fff libCSync.A.dylib ??? (???) <7ccecf2b36209e1196c42c635938519e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x91b51000 - 0x91b6dffb com.apple.openscripting 1.2.8 (???) <01f86cdb8f7347d2f3f13066e954acb6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x91b6e000 - 0x91b77fff com.apple.DiskArbitration 2.2.1 (2.2.1) <682f5c45591e8c4a89c79e384e2c49af> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91bc7000 - 0x91be6fff com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x91be7000 - 0x91d52ffb com.apple.MediaToolbox 0.484.2 (484.2) <526ed0b23c36f41a6165252b1b2ad3e2> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x91d53000 - 0x91d7afff libcups.2.dylib ??? (???) <3ec5cc45c49c9e3deef8f0bd18b8dc50> /usr/lib/libcups.2.dylib
0x91d7b000 - 0x91e35fff libcrypto.0.9.7.dylib ??? (???) <1d82e65c85d65367f3b6b06355c89c9b> /usr/lib/libcrypto.0.9.7.dylib
0x91e36000 - 0x923b2ff7 com.apple.CoreGraphics 1.409.5 (???) <5055e3621c3a2239851bd7e829e94ea1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x923b3000 - 0x923beff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x923bf000 - 0x9244effb com.apple.DesktopServices 1.4.8 (1.4.8) <efaf20fbcdf58c7da37ddbcf190bba75> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9244f000 - 0x92778fe7 libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92779000 - 0x9288dffa com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9288e000 - 0x928cbfff libRIP.A.dylib ??? (???) <a710b7ef58700a54a39e7738dd804e57> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x928cc000 - 0x92963fff com.apple.LaunchServices 292 (292) <06cb373fd960fbc2b4a0201f55c7dd6d> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92964000 - 0x92972ff3 com.apple.opengl 1.5.10 (1.5.10) <54bae289e544387ce7997a4a05e70aa9> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x92973000 - 0x92a43fff com.apple.ColorSync 4.5.3 (4.5.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x92a44000 - 0x92a62fff com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x92a63000 - 0x92af8ff7 com.apple.framework.IOKit 1.5.2 (???) <ced0a498252f76a2d2ba9f2a0ae02160> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x92af9000 - 0x92c9aff7 com.apple.QuartzComposer 2.1 (106.13) <6dd1df71cb588b1b9ceb0c5bbf32e842> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x92c9b000 - 0x92caafff com.apple.DSObjCWrappers.Framework 1.3 (1.3) <305892aafaceb4e31915f0d759ef7e6d> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x92dbf000 - 0x92f0bfff com.apple.ImageIO.framework 2.0.7 (2.0.7) <c466caa621b9fa7431877610c21e39a6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x92f0c000 - 0x92f0fffb com.apple.securityhi 3.0 (30817) <e50c0cac9048f8923b95797753d50b5c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9390a000 - 0x9393ffff com.apple.AE 402.3 (402.3) <75725936d014fd3ca2553d18b784b99b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x93940000 - 0x93948fff libbsm.dylib ??? (???) <c1fca3cbe3b1c21e9b31bc89b920f34c> /usr/lib/libbsm.dylib
0x93949000 - 0x9394cfff com.apple.help 1.1 (36) <7106d6e074a3b9835ebf1e6cc6c822ce> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9394d000 - 0x939d5fff com.apple.ink.framework 101.3 (86) <66a99ad6bc695390a66dd24789e23dcc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x939d6000 - 0x939f1ff3 com.apple.DirectoryService.Framework 3.5.7 (3.5.7) <d7f3680b677d574b5b77b30aca4d3604> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x93a28000 - 0x93c11fff com.apple.security 5.0.6 (37592) <e945bd5cce817d5a95e2671659e5107a> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x93c12000 - 0x93c25fff com.apple.LangAnalysis 1.6.5 (1.6.5) <2a661ad6e432dd62dd831e234904061f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x93d4d000 - 0x93d4dffa com.apple.CoreServices 32 (32) <42b6dda539f7411606187335d9eae0c5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93d4e000 - 0x93d8fffb libTIFF.dylib ??? (???) <a4fac1b78bf536e570841166630ff642> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x93dc1000 - 0x94007ffb com.apple.Foundation 6.5.9 (677.26) <c30e4aea51bbae480d4550cd53abb441> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x94008000 - 0x94018ffb com.apple.agl 3.0.9 (AGL-3.0.9) <e751a9e491c3a9ef82c6405466106726> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x942db000 - 0x942dbffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x942dc000 - 0x942f3ffb com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x942f8000 - 0x9462ffff com.apple.QuickTime 7.6.6 (1674) <47978052d9aef79174eecaaa75b92a2a> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94630000 - 0x9466efff com.apple.CoreMedia 0.484.2 (484.2) <d2d58e0e9ed09a02cc7d96395251d26f> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9466f000 - 0x947c6ff7 com.apple.JavaScriptCore 5531.22 (5531.22.5) <1fcfa75230382de3407e47518205e0db> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x947c7000 - 0x9481dfff libGLU.dylib ??? (???) <3418ce7ca0863162847f553c15d08674> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9481e000 - 0x94a21fff com.apple.VideoToolbox 0.484.2 (484.2) <e186b5114a9f3e8c74f8b7f5f7971b15> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x94a22000 - 0x94a3effb libPng.dylib ??? (???) <036c49544cb7b1d09d5e0185a1e26f7d> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94a3f000 - 0x94a4bff3 com.apple.audio.SoundManager 3.9.2 (3.9.2) <79588842bcaf6c747a95b2120304397a> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x94a4c000 - 0x94ad6fff libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x94ad7000 - 0x94b87fff edu.mit.Kerberos 6.0.13 (6.0.13) <2ed20a450576465ee4f9c317b8ce8c44> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94b88000 - 0x94e8affb com.apple.CoreServices.CarbonCore 786.11 (786.14) <4da8e0984e333f8cea32a24ba4364e8c> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94efb000 - 0x94f5cfff com.apple.CoreText 2.0.4 (???) <ebcc2c7e9b0bc10016af530d82a11f03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x94f5d000 - 0x94fffffb com.apple.QuickTimeImporters.component 7.6.6 (1674) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x95000000 - 0x95000ffc com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <91aadd6dccda219dd50a6ce06aad5b54> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x9502b000 - 0x9507afff com.apple.CoreMediaIOServices 130.0 (935) <b06537905646103bf7ebb899b569d355> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x9507b000 - 0x950b4fff com.apple.SystemConfiguration 1.9.2 (1.9.2) <21dee7ffd93306032f911b5ef3fdbab3> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x95185000 - 0x9520afff libsqlite3.0.dylib ??? (???) <daf55b073488086ef5b9a3781be53f14> /usr/lib/libsqlite3.0.dylib
0x9520b000 - 0x9520fffe libGIF.dylib ??? (???) <cc34b3a44618a0e1ccc1c5b1cf28b5bb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x95210000 - 0x95d7dfef com.apple.QuickTimeComponents.component 7.6.6 (1674) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x95d7e000 - 0x95dcdfff com.apple.Metadata 10.5.8 (398.26) <1a261534027b9d1518327d1fabe1182b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95dd5000 - 0x95df6ffb com.apple.AppleVAFramework 4.1.16 (4.1.16) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x95df7000 - 0x95e0affb com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <050180a659a3905ea38f2acddcdf7b40> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x95e36000 - 0x95f5bff3 com.apple.CoreFoundation 6.5.7 (476.19) <dee0f0024f3bf976cfa0a0816e8aa338> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x95f5c000 - 0x95f7bfff libresolv.9.dylib ??? (???) <c5c72e1cf61cb844163156956a1d8407> /usr/lib/libresolv.9.dylib
0x95f7c000 - 0x962b5ff7 com.apple.HIToolbox 1.5.6 (???) <a3b713a77c16da495c886463985f1e39> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x962e9000 - 0x962eafff libffi.dylib ??? (???) <11b77dbce4aa0f0b66d40014230abd1d> /usr/lib/libffi.dylib
0x962eb000 - 0x962ebff8 com.apple.Cocoa 6.5 (???) <e9a4f1c636d00893db0494c4040176ba> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x962ec000 - 0x962f3fff com.apple.CommonPanels 1.2.4 (85) <0d1256175c5512c911ede094d767acfe> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x962f4000 - 0x962f5ff8 com.apple.ApplicationServices 34 (34) <6aa5ee485bb2e656531b3505932b845f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x962f6000 - 0x9638ffc3 libvDSP.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96390000 - 0x963fafff com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x9643b000 - 0x9645affb com.apple.CoreVideo 1.6.1 (48.6) <4a3dfc7082a48c4e3c99ed644f49b9ba> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9645b000 - 0x96461fff com.apple.DisplayServicesFW 2.0.2 (2.0.2) <7f4de3ca234fdf3f06f25d47d7119e9b> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x96474000 - 0x964fcffb com.apple.audio.CoreAudio 3.1.2 (3.1.2) <6fc8a8cb43506b57b951da899a55d3b9> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x96519000 - 0x96544ff7 libauto.dylib ??? (???) <a64d088b2d17e013b9ee5a08d3a20d33> /usr/lib/libauto.dylib
0x96545000 - 0x965a2ffb com.apple.HIServices 1.7.1 (???) <a6c5c0bf2d68aeb453dbc493b7d0c8d9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x965a3000 - 0x9663dff7 com.apple.ApplicationServices.ATS 3.8.1 (???) <6b490d945417fa114cfa607608c6b58e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x967df000 - 0x968c2fff libobjc.A.dylib ??? (???) <a1d4be2eed463c6799b6a1447fde72ba> /usr/lib/libobjc.A.dylib
0x968c3000 - 0x968d1fff libz.1.dylib ??? (???) <1a70dd3594a8c5ad39d785af5da23237> /usr/lib/libz.1.dylib
0x968d2000 - 0x968ddfff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <ae3dc890a43a9269388301f6b59d3091> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x968de000 - 0x968e0ffd libRadiance.dylib ??? (???) <304e574d5de8d26630c4c516cc6e47fb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x968e1000 - 0x96948ffb libstdc++.6.dylib ??? (???) <a4e9b10268b3ffac26d0296499b24e8e> /usr/lib/libstdc++.6.dylib
0x96949000 - 0x969abffb com.apple.htmlrendering 68 (1.1.3) <e852db1c007de975fae2f0c2769c88ef> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x969ac000 - 0x969eefff com.apple.quartzfilters 1.5.0 (1.5.0) <3f2dc01a646cd5b5ea55d510583ba4d5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x969ef000 - 0x96bb1ff4 com.apple.CoreAUC 3.08.0 (3.08.0) <2bb108ce3279d71f656c30b5a527521b> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x96bb2000 - 0x96cfaff3 libicucore.A.dylib ??? (???) <bdab570d90979c4f601131d442f84720> /usr/lib/libicucore.A.dylib
0x96cfb000 - 0x96d00ff6 libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x96d01000 - 0x96d09ffb libCGATS.A.dylib ??? (???) <72ecb94f23cdc622a277671b4976a7d8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x96d51000 - 0x96e19ffb com.apple.CoreData 100.2 (186.2) <be912ff41bd4506438a71d5665e89069> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x96e1a000 - 0x96e9cfff com.apple.print.framework.PrintCore 5.5.4 (245.6) <3cde2550ec10348b7162d2b6cb0dfc67> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x96ebd000 - 0x97004ffb com.apple.audio.toolbox.AudioToolbox 1.5.3 (1.5.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x97005000 - 0x971a5fe3 libSystem.B.dylib ??? (???) <45c5920425c80bf594b3f1bde2382e95> /usr/lib/libSystem.B.dylib
0x971a6000 - 0x97290fff libxml2.2.dylib ??? (???) <c16d0fbbf8fd6b30695cd3c930355066> /usr/lib/libxml2.2.dylib
0x97291000 - 0x972befff libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9730f000 - 0x973bffff com.apple.QD 3.11.57 (???) <e74b370c6f81fc00e8936f5cf7c8ebe0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x973c0000 - 0x973e9ffb com.apple.shortcut 1.0.1 (1.0) <8da20d176ab4cf71cdf4f79b477fe0e7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x973ea000 - 0x9741bfff com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9748d000 - 0x9748dffe com.apple.quartzframework 1.5 (1.5) <1477ba992c53f43087c7527c4782fd54> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x9748e000 - 0x974aeff7 libJPEG.dylib ??? (???) <bcc63fc19e0a5fa3d4b411f0de1d5851> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9751c000 - 0x9751cfff com.apple.Carbon 136 (136) <6a6a209ec9179368db7ead8382b8ee63> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9751d000 - 0x97642ffb com.apple.imageKit 1.0.2 (1.0) <50dfcbe41b384bd71761c761c3fbfd5e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x97659000 - 0x97678fff com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9777c000 - 0x977c6fff com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x977c7000 - 0x9780efff com.apple.NavigationServices 3.5.2 (163) <453fd79dd63debad4908dcc726f9aa04> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0xba900000 - 0xba917ffe libJapaneseConverter.dylib ??? (???) <ddbf52237a078e0b4f6b1a408b4f272a> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21ffc libKoreanConverter.dylib ??? (???) <0a2ba63ad56ef171914b3f6421a63730> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xfffec000 - 0xfffeffff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff8000 - 0xffff9703 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
Any help?
sugardilly
Post by sugardilly »
The Crashing is making me crazy too. It's good to see someone else facing the same issues. I hope I get some help. I've already disabled Spotlight and the crashing continues. Here is the recent log. Can someone read this and please help.
Host Name: Studio-Computer
Date/Time: 2010-06-05 18:30:59.042 -0400
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: Digital Performer
Path: /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/Digital Performer
Parent: WindowServer [61]
PID: 278
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x000000aa
Thread 0 Crashed:
0 com.apple.QD 0x9175b408 RSect2 + 0
1 com.apple.QD 0x9177101c CalculateMinRectAndTrim + 56
2 com.apple.QD 0x91773548 SetupOtherDrawVars + 360
3 com.apple.QD 0x91779084 DevFrameRect + 400
4 com.apple.QD 0x917730d0 StdRectWithPort + 268
5 com.apple.QD 0x91778ee0 FrameRect + 52
6 DPPart2.dylib 0x01acbd78 MeterBridgeScaleBar::dBToMeterValue(float) + 7644
7 PerfFoundation.dylib 0x02b8c170 GlogPane::RedrawInRegion(OpaqueRgnHandle*) + 280
8 PerfFoundation.dylib 0x02b79b58 CompoundPane::SetUseLayout(bool) + 212
9 PerfFoundation.dylib 0x02b7a464 CompoundPane::_Iterate(bool, long (*)(GlogPane*, void*, short), void*) + 160
10 PerfFoundation.dylib 0x02b7b018 CompoundPane::DrawGuts(OpaqueRgnHandle*) + 328
11 PerfFoundation.dylib 0x02b8c170 GlogPane::RedrawInRegion(OpaqueRgnHandle*) + 280
12 PerfFoundation.dylib 0x02b79b58 CompoundPane::SetUseLayout(bool) + 212
13 PerfFoundation.dylib 0x02b7a464 CompoundPane::_Iterate(bool, long (*)(GlogPane*, void*, short), void*) + 160
14 PerfFoundation.dylib 0x02b7b018 CompoundPane::DrawGuts(OpaqueRgnHandle*) + 328
15 PerfFoundation.dylib 0x02b8c170 GlogPane::RedrawInRegion(OpaqueRgnHandle*) + 280
16 PerfFoundation.dylib 0x02b79b58 CompoundPane::SetUseLayout(bool) + 212
17 PerfFoundation.dylib 0x02b7a464 CompoundPane::_Iterate(bool, long (*)(GlogPane*, void*, short), void*) + 160
18 PerfFoundation.dylib 0x02b7b018 CompoundPane::DrawGuts(OpaqueRgnHandle*) + 328
19 PerfFoundation.dylib 0x02b8c170 GlogPane::RedrawInRegion(OpaqueRgnHandle*) + 280
20 PerfFoundation.dylib 0x02b79b58 CompoundPane::SetUseLayout(bool) + 212
21 PerfFoundation.dylib 0x02b7a464 CompoundPane::_Iterate(bool, long (*)(GlogPane*, void*, short), void*) + 160
22 PerfFoundation.dylib 0x02b7b018 CompoundPane::DrawGuts(OpaqueRgnHandle*) + 328
23 PerfFoundation.dylib 0x02b8c170 GlogPane::RedrawInRegion(OpaqueRgnHandle*) + 280
24 PerfFoundation.dylib 0x02b8cbd4 GlogPane::GlogMessage(short, long) + 200
25 PerfFoundation.dylib 0x02b7763c GlogWindowPane::ProcessUpdateForOneScreen(OpaqueRgnHandle*) + 160
26 PerfFoundation.dylib 0x02b7793c GlogWindowPane::LayoutIsInvalid(GlogLayoutRectItem*) + 220
27 PerfFoundation.dylib 0x02b711b8 PinEntireRectToScreen(Rect*) + 460
28 com.apple.QD 0x91777d4c CommonDeviceLoop + 312
29 PerfFoundation.dylib 0x02b713f0 PerfDeviceLoopThrow(OpaqueRgnHandle*, void (*)(long), long, unsigned long) + 460
30 PerfFoundation.dylib 0x02b71498 PerfDeviceLoop(OpaqueRgnHandle*, void (*)(long), long, unsigned long) + 16
31 PerfFoundation.dylib 0x02b77a5c GlogWindowPane::ProcessUpdate() + 228
32 PerfFoundation.dylib 0x02b81038 UpdateGlog(glogRec*) + 112
33 PerfFoundation.dylib 0x02b92b98 WithDeferredGlogUpdates::DoUpdates() + 52
34 PerfEngine.dylib 0x02550b84 MaybeRTPoll(bool) + 1560
35 PerfFoundation.dylib 0x02bca6c0 PeriodicEvents::Timer::DoAction() + 144
36 PerfFoundation.dylib 0x02bca358 UIEventUtil::ReceiveNextEvent(unsigned long, UIEventUtil::UIEventTypeSpec const*, double, std::auto_ptr<UIEvent>&) + 136
37 com.apple.CoreFoundation 0x907f2384 __CFRunLoopDoTimer + 184
38 com.apple.CoreFoundation 0x907decfc __CFRunLoopRun + 1680
39 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268
40 com.apple.HIToolbox 0x932bcb20 RunCurrentEventLoopInMode + 264
41 com.apple.HIToolbox 0x932bc1b4 ReceiveNextEventCommon + 380
42 com.apple.HIToolbox 0x93301348 AcquireNextEventInMode + 72
43 com.apple.HIToolbox 0x93301138 RunApplicationEventLoop + 132
44 com.motu.DigitalPerformer 0x0062e268 0x1000 + 6476392
45 com.motu.DigitalPerformer 0x00003bfc 0x1000 + 11260
46 com.motu.DigitalPerformer 0x00003900 0x1000 + 10496
Thread 1:
0 libSystem.B.dylib 0x90040df8 mach_wait_until + 8
1 libSystem.B.dylib 0x90040bc4 nanosleep + 388
2 libSystem.B.dylib 0x90044398 usleep + 88
3 PerfMSL.dylib 0x00ff1b7c PerfAssert::SetEnableDebugMsgs(bool) + 6276
4 PerfMSL.dylib 0x00ff1774 PerfAssert::SetEnableDebugMsgs(bool) + 5244
5 libSystem.B.dylib 0x9002b908 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x9000af48 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000ae9c mach_msg + 60
2 PerfFoundation.dylib 0x02b9e9ac PerfWorkerThread::GetThread() + 920
3 PerfFoundation.dylib 0x02b9eaa0 PerfWorkerThread::GetThread() + 1164
4 libSystem.B.dylib 0x9002b908 _pthread_body + 96
Thread 3:
0 libSystem.B.dylib 0x90130d78 semaphore_timedwait_trap + 8
1 AllUtilities.dylib 0x00fa14a4 PerfSemaphore::timed_wait(long) + 100
2 PerfEngine.dylib 0x0266a90c PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 840
3 PerfEngine.dylib 0x0266a958 PerfAudioCache::RunJobs(std::vector<workq_ele_t*, std::allocator<workq_ele_t*> >&) + 916
Thread 4:
2 com.apple.audio.MIDI.CoreMIDI 0x966c3ac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84
3 com.apple.audio.MIDI.CoreMIDI 0x966b6c80 MIDIInPortThread::Run() + 64
4 com.apple.audio.MIDI.CoreMIDI 0x966baf44 XThread::RunHelper(void*) + 28
5 com.apple.audio.MIDI.CoreMIDI 0x966c487c CAPThread::Entry(CAPThread*) + 96
6 libSystem.B.dylib 0x9002b908 _pthread_body + 96
Thread 5:
2 com.apple.CoreFoundation 0x907de9ac __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268
4 com.apple.audio.CoreAudio 0x91459524 HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
Thread 6:
2 com.motu.MAS.framework 0x0215f074 dyld_stub_NSAddressOfSymbol + 34543956
3 com.motu.MAS.framework 0x0215f1d4 dyld_stub_NSAddressOfSymbol + 34544308
Thread 7:
0 libSystem.B.dylib 0x9002c0b8 semaphore_wait_trap + 8
1 com.motu.MAS.framework 0x0211c534 dyld_stub_NSAddressOfSymbol + 34270740
2 com.motu.MAS.framework 0x0215e7c4 dyld_stub_NSAddressOfSymbol + 34541732
3 libSystem.B.dylib 0x9002b908 _pthread_body + 96
Thread 8:
1 ...ple.CoreServices.CarbonCore 0x90bfdd4c MPDelayUntil + 60
2 ...ple.CoreServices.CarbonCore 0x90bfdb94 Delay + 124
3 ...opellerheads.rewire.library 0x109ea4b0 RWPUnregisterDeviceImp + 3096
4 ...opellerheads.rewire.library 0x10a22a08 RWPUnregisterDeviceImp + 233840
Thread 9:
1 com.motu.MAS.framework 0x021a7738 MasEffectHelper_AllocateBuffer + 185680
2 com.motu.MAS.framework 0x021a77b8 MasEffectHelper_AllocateBuffer + 185808
Thread 10:
Thread 11:
0 libSystem.B.dylib 0x90053f88 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x900707e8 pthread_cond_timedwait_relative_np + 556
2 com.apple.audio.CoreAudio 0x9146a6ac CAGuard::WaitFor(unsigned long long) + 204
3 com.apple.audio.CoreAudio 0x9146a5bc CAGuard::WaitUntil(unsigned long long) + 304
4 com.apple.audio.CoreAudio 0x91468800 HP_IOThread::WorkLoop() + 852
5 com.apple.audio.CoreAudio 0x91468498 HP_IOThread::ThreadEntry(HP_IOThread*) + 16
6 com.apple.audio.CoreAudio 0x914592c4 CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x9002b908 _pthread_body + 96
Thread 12:
1 PerfEngine.dylib 0x0240e038 TrackGroupManager::TrackGroupManager[not-in-charge]() + 1756
2 libSystem.B.dylib 0x9002b908 _pthread_body + 96
Thread 13:
Thread 14:
2 PerfFoundation.dylib 0x02ba12a0 GetUnitTestRandomLong() + 112
Thread 15:
Thread 16:
2 ...ple.CoreServices.CarbonCore 0x90bf9330 TSWaitOnSemaphoreCommon + 176
3 ...ple.CoreServices.CarbonCore 0x90bf9184 AsyncFileThread(void*) + 56
Thread 0 crashed with PPC Thread State 64:
srr0: 0x000000009175b408 srr1: 0x000000000000f030 vrsave: 0x0000000000000000
cr: 0x44028224 xer: 0x0000000000000004 lr: 0x000000009177101c ctr: 0x0000000090375c58
r0: 0x00000000ffffffff r1: 0x00000000bfffd7a0 r2: 0x0000000000000000 r3: 0x00000000000000aa
r4: 0x00000000bfffd91e r5: 0x00000000bfffd99a r6: 0x0000000003927050 r7: 0x0000000000000000
r8: 0x0000000000000005 r9: 0x0000000000000000 r10: 0x00000000006e0016 r11: 0x00000000a174ea78
r12: 0x0000000090375c58 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000
r16: 0x0000000000000000 r17: 0x00000000bfffebf8 r18: 0x0000000000000000 r19: 0x0000000000000000
r20: 0x000000007fffffff r21: 0x00000000bfffec0c r22: 0x0000000002b710f8 r23: 0x0000000008b8950c
r24: 0x0000000000000000 r25: 0x00000000000000aa r26: 0x0000000000000000 r27: 0x00000000000000aa
r28: 0x00000000129a4420 r29: 0x00000000bfffd99a r30: 0x00000000bfffd8c0 r31: 0x00000000917733f8
Binary Images Description:
0x1000 - 0xb54fff com.motu.DigitalPerformer 6.03 /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/Digital Performer
0xf96000 - 0xfb1fff AllUtilities.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/AllUtilities.dylib
0xfc5000 - 0xfd0fff FileSystem.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/FileSystem.dylib
0xfdc000 - 0xfdefff com.motu.MPO.framework MotuPublicObjects 3.1 (3.1) /Applications/Digital Performer/Digital Performer 6.03.app/Contents/Frameworks/MotuPublicObjects.framework/Versions/A/MotuPublicObjects
0xfe1000 - 0xfe6fff PerfError.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/PerfError.dylib
0xfec000 - 0xff6fff PerfMSL.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/PerfMSL.dylib
0x1808000 - 0x184ffff DPBasicUI.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/DPBasicUI.dylib
0x187e000 - 0x1881fff ResourceAccess.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/ResourceAccess.dylib
0x1886000 - 0x189cfff XML.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/XML.dylib
0x18aa000 - 0x18c8fff PerfOSInterface.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/PerfOSInterface.dylib
0x1a05000 - 0x1c8dfff DPPart2.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/DPPart2.dylib
0x1e81000 - 0x1ed3fff GenericPanes.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/GenericPanes.dylib
0x1f30000 - 0x1fa5fff HiLevelWrappers.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/HiLevelWrappers.dylib
0x1fd4000 - 0x20cbfff com.motu.MidiSystem MidiSystem version 1.0 (1.0) /Applications/Digital Performer/Digital Performer 6.03.app/Contents/Frameworks/MidiSystem.framework/Versions/A/MidiSystem
0x2110000 - 0x21c5fff com.motu.MAS.framework 4.0.0 /Applications/Digital Performer/Digital Performer 6.03.app/Contents/Frameworks/MotuAudioSystem.framework/Versions/A/MotuAudioSystem
0x21e5000 - 0x22c6fff com.motu.DAE MotuDAE™ 1.0 (1.0) /Applications/Digital Performer/Digital Performer 6.03.app/Contents/Frameworks/MotuDAE.framework/Versions/A/MotuDAE
0x2304000 - 0x23c0fff OMF_AAF.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/OMF_AAF.dylib
0x23da000 - 0x2905fff PerfEngine.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/PerfEngine.dylib
0x2b4b000 - 0x2c8cfff PerfFoundation.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/PerfFoundation.dylib
0x2d34000 - 0x2dfafff PureDSP.dylib /Applications/Digital Performer/Digital Performer 6.03.app/Contents/MacOS/PureDSP.dylib
0x2ffb000 - 0x2ffdfff com.apple.textencoding.unicode 2.0 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x35fa000 - 0x35f9fff RVerbProcess PEF binary: RVerbProcess
0x4b1f000 - 0x4b36fff com.MOTU.plugin.AudioExport.CoreAudio Core Audio Export version 1.41, 3/23/06 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/Core Audio Export.bundle/Contents/MacOS/Core Audio Export
0x7cf9000 - 0x7cfefff com.apple.LiveType.component 2.1.3 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x8b50000 - 0x8b5ffff com.shepmater.A52Codec 1.7.8 /Users/fredferguson1/Library/Audio/Plug-Ins/Components/A52Codec.component/Contents/MacOS/A52Codec
0x8b66000 - 0x8b74fff net.telestream.license 1.0.7.2 /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
0x8bcb000 - 0x8c30fff com.apple.LiveType.framework 2.1.3 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x8c52000 - 0x8c59fff com.MOTU.plugin.AudioExport.LAME 1.2.1 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/LAME Audio Export.bundle/Contents/MacOS/LAME Audio Export
0x8d90000 - 0x8f46fff com.apple.audio.codecs.Components 1.5.6 /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x8fa5000 - 0x8fbdfff com.MOTU.plugin.AudioExport.QT 2.0 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/QuickTime Export.bundle/Contents/MacOS/QuickTime Export
0x9025000 - 0x92e4fff org.perian.Perian 1.1.4 /Users/fredferguson1/Library/QuickTime/Perian.component/Contents/MacOS/Perian
0x9674000 - 0x9859fff net.telestream.wmv.import 2.3.2.6 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x988d000 - 0x98befff net.sourceforge.LAMEframework 3.97 (1.0) /Library/Frameworks/LAME.framework/Versions/A/LAME
0x98f8000 - 0x9919fff com.MOTU.plugin.AudioExport.LAME LAME Audio Export version 1.01, 2/6/06 (1.0) /Library/Audio/Plug-Ins/MOTU Audio Export/LAMEAudioExport.bundle/Contents/MacOS/LAMEAudioExport
0x9b12000 - 0x9b4bfff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x9bec000 - 0x9bedfff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x9bf0000 - 0x9c32fff com.motu.driver.FWA.HALPlugin ??? (1.5 38352) /System/Library/Extensions/MOTUFireWireAudio.kext/Contents/PlugIns/FWHALPlugin.bundle/Contents/MacOS/FWHALPlugin
0x9d26000 - 0x9d28a4b vecLib PEF binary: vecLib
0x9e63000 - 0x9f78fff com.MOTU.MAS.plugin.ArcPan 2.4 /Library/Audio/Plug-Ins/MAS/Arc Panner.bundle/Contents/MacOS/Arc Panner
0xa105000 - 0xa229fff com.MOTU.MAS.plugin.Auralizer 2.4 /Library/Audio/Plug-Ins/MAS/Auralizer.bundle/Contents/MacOS/Auralizer
0xa296000 - 0xa33ffff com.MOTU.MAS.plugin.AutoPan 4.3 /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
0xa388000 - 0xa426fff com.MOTU.MAS.plugin.BassManager 2.3 /Library/Audio/Plug-Ins/MAS/Bass Manager.bundle/Contents/MacOS/Bass Manager
0xa466000 - 0xa66cfff com.motu.mas.plugin.BassLine 1.0 /Library/Audio/Plug-Ins/MAS/BassLine.bundle/Contents/MacOS/BassLine
0xa7c3000 - 0xa822fff com.MOTU.MAS.plugin.Buffy 2.4 /Library/Audio/Plug-Ins/MAS/Buffy.bundle/Contents/MacOS/Buffy
0xa850000 - 0xa90ffff com.MOTU.MAS.plugin.Calibration 2.3 /Library/Audio/Plug-Ins/MAS/Calibration.bundle/Contents/MacOS/Calibration
0xa95c000 - 0xa9e0fff com.MOTU.MAS.plugin.Chorus 3.3 /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
0xaa1f000 - 0xaa6cfff com.MOTU.MAS.plugin.DCNotch 4.3 /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
0xaa8f000 - 0xab9dfff com.MOTU.MAS.plugin.Delay 3.3 /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
0xac00000 - 0xac90fff com.MOTU.MAS.plugin.Dynamics 3.3 /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
0xacd0000 - 0xad51fff com.MOTU.MAS.plugin.Echo 3.3 /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
0xad90000 - 0xae8dfff com.MOTU.MAS.plugin.eVerb 4.4 /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
0xaeeb000 - 0xaf83fff com.MOTU.MAS.plugin.Flanger 4.3 /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
0xafc8000 - 0xafdcfff com.MOTU.MAS.plugin.InvertPhase InvertPhase version 1.0.2, 11/11/04 (1.0.1) /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
0xb105000 - 0xb15cfff com.MOTU.MAS.AudioUnitWrapper 1.5.alpha5 (1.5.b5) /Library/Audio/Plug-Ins/MAS/MAS AudioUnit Support.bundle/Contents/MacOS/MAS AudioUnit Support
0xb1d3000 - 0xb26cfff com.MOTU.MAS.plugin.MWCompressor 3.4 /Library/Audio/Plug-Ins/MAS/MasterWorks Compressor.bundle/Contents/MacOS/MasterWorks Compressor
0xb2b5000 - 0xb3d2fff com.MOTU.MAS.plugin.MWEQ 1.2 /Library/Audio/Plug-Ins/MAS/MasterWorks EQ.bundle/Contents/MacOS/MasterWorks EQ
0xb43f000 - 0xb4dffff com.MOTU.MAS.plugin.MWGate 2.3 /Library/Audio/Plug-Ins/MAS/MasterWorks Gate.bundle/Contents/MacOS/MasterWorks Gate
0xb52a000 - 0xb668fff com.MOTU.MAS.plugin.MWLeveler 1.3 /Library/Audio/Plug-Ins/MAS/MasterWorks Leveler.bundle/Contents/MacOS/MasterWorks Leveler
0xb6ac000 - 0xb78cfff com.MOTU.MAS.plugin.MWLimiter 4.3 /Library/Audio/Plug-Ins/MAS/MasterWorks Limiter.bundle/Contents/MacOS/MasterWorks Limiter
0xb7f1000 - 0xbb53fff com.MOTU.MAS.plugin.Model12 1.0 (1.0a4) /Library/Audio/Plug-Ins/MAS/Model12.bundle/Contents/MacOS/Model12
0xc005000 - 0xc334fff com.motu.mas.plugin.modulo 1.0 /Library/Audio/Plug-Ins/MAS/Modulo.bundle/Contents/MacOS/Modulo
0xc805000 - 0xc867fff com.MOTU.MAS.plugin.MSDecoder 2.3 /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
0xc895000 - 0xc948fff com.MOTU.MAS.plugin.MultiModeFilter 2.3 /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
0xc99e000 - 0xca95fff com.MOTU.MAS.plugin.MultiPan 2.4 /Library/Audio/Plug-Ins/MAS/n-Panner.bundle/Contents/MacOS/n-Panner
0xcaff000 - 0xce4dfff com.motu.mas.plugin.nanosampler 1.0 /Library/Audio/Plug-Ins/MAS/nanosampler.bundle/Contents/MacOS/nanosampler
0xd1dd000 - 0xd2e3fff com.MOTU.MAS.plugin.ParaEQ 4.3 /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
0xd33a000 - 0xd408fff com.MOTU.MAS.plugin.PatternGate 1.1 /Library/Audio/Plug-Ins/MAS/PatternGate.bundle/Contents/MacOS/PatternGate
0xd4be000 - 0xd4c7fff com.MOTU.MAS.plugin.Reverse Reverse version 1.0.1, 8/10/03 (1.0.1) /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
0xd4d0000 - 0xd4e3d3f AudioTrack 5.0.1 PEF binary: AudioTrack 5.0.1
0xd4f1000 - 0xd4ff60f IDR 5.0 PEF binary: IDR 5.0
0xd5e1b40 - 0xd5e1bf2 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
0xd5e21c0 - 0xd5e2237 CFMPriv_System PEF binary: CFMPriv_System
0xd5e23a0 - 0xd5e243a CFMPriv_vecLib PEF binary: CFMPriv_vecLib
0xd5e24b0 - 0xd5e2580 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
0xd5e25f0 - 0xd5e26c3 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
0xd5e2790 - 0xd5e284b CFMPriv_Help PEF binary: CFMPriv_Help
0xd5e2850 - 0xd5e291a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
0xd5e2990 - 0xd5e2a66 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
0xd5e2ad0 - 0xd5e2ba3 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
0xd5e2c20 - 0xd5e2d05 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
0xd5e2d70 - 0xd5e2e46 CFMPriv_OpenScriptingMacBLib PEF binary: CFMPriv_OpenScriptingMacBLib
0xd5e2f10 - 0xd5e2fce CFMPriv_Print PEF binary: CFMPriv_Print
0xd5e2fe0 - 0xd5e30ad CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
0xd5e3120 - 0xd5e3202 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
0xd5e3270 - 0xd5e3343 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
0xd5e33b0 - 0xd5e3483 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
0xd5e3550 - 0xd5e3612 CFMPriv_AE PEF binary: CFMPriv_AE
0xd5e3620 - 0xd5e36e5 CFMPriv_ATS PEF binary: CFMPriv_ATS
0xd5e3750 - 0xd5e3827 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
0xd5e38a0 - 0xd5e3983 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
0xd5e39f0 - 0xd5e3aca CFMPriv_HIServices PEF binary: CFMPriv_HIServices
0xd5e3b30 - 0xd5e3c10 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
0xd5e3c90 - 0xd5e3d76 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
0xd5e3e40 - 0xd5e3f17 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
0xd5e3f20 - 0xd5e3fe2 CFMPriv_QD PEF binary: CFMPriv_QD
0xd5e40d0 - 0xd5e41b9 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
0xd605000 - 0xd698fff com.MOTU.MAS.plugin.Phaser 4.3 /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
0xd6da000 - 0xd777fff com.MOTU.MAS.plugin.Plate 2.3 /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
0xd7c3000 - 0xd9ddfff com.motu.mas.plugin.PolySynth 1.0 /Library/Audio/Plug-Ins/MAS/PolySynth.bundle/Contents/MacOS/PolySynth
0xdb55000 - 0xdc02fff com.MOTU.MAS.plugin.Preamp 3.3 /Library/Audio/Plug-Ins/MAS/PreAmp-1.bundle/Contents/MacOS/PreAmp-1
0xdc58000 - 0xdee0fff com.motu.mas.plugin.proton 1.0 /Library/Audio/Plug-Ins/MAS/Proton.bundle/Contents/MacOS/Proton
0xe13f000 - 0xe721fff com.MOTU.MAS.plugin.ProVerb 1.1.1 /Library/Audio/Plug-Ins/MAS/ProVerb.bundle/Contents/MacOS/ProVerb
0xe805000 - 0xe86efff com.MOTU.MAS.plugin.QuanJr 2.3 /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
0xe89f000 - 0xe904fff com.MOTU.MAS.plugin.Reverb 3.3 /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
0xe933000 - 0xe9bcfff com.MOTU.MAS.plugin.RingMod 2.3 /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
0xe9fe000 - 0xeacdfff com.MOTU.MAS.plugin.SonicModulator 3.3 /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
0xeb38000 - 0xebc2fff com.MOTU.MAS.plugin.Tremolo 4.3 /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
0xec03000 - 0xec89fff com.MOTU.MAS.plugin.Trigger 2.3 /Library/Audio/Plug-Ins/MAS/Trigger.bundle/Contents/MacOS/Trigger
0xecc9000 - 0xed77fff com.MOTU.MAS.plugin.Trim 4.3 /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
0xedc3000 - 0xef0cfff com.MOTU.MAS.plugin.TriPan 2.4 /Library/Audio/Plug-Ins/MAS/TriPan.bundle/Contents/MacOS/TriPan
0xef79000 - 0xf1cbfff com.izotope.audioplugins.MAS.Vinyl 1.7.3 (1.7.3b533) /Library/Audio/Plug-Ins/MAS/Vinyl.bundle/Contents/MacOS/Vinyl
0xf232000 - 0xf283fff com.Waves.MAS.plugin.shell WaveShell-MAS 5.0.1 (5.0.1) /Library/Audio/Plug-Ins/MAS/WaveShell-MAS 5.0.1.bundle/Contents/MacOS/WaveShell-MAS 5.0.1
0xf2b2000 - 0xf56f476 WavesLib 5.0b1 PEF binary: WavesLib 5.0b1
0xf572000 - 0xf5c13c7 CarbonLibpwpc PEF binary: CarbonLibpwpc
0xf5dd000 - 0xf625b3e MSL_All_Carbon.Shlb PEF binary: MSL_All_Carbon.Shlb
0xf6e5000 - 0xf700077 C1 5.0.1 PEF binary: C1 5.0.1
0xf723000 - 0xf7336c3 DeEsser 5.0p PEF binary: DeEsser 5.0p
0xf767000 - 0xf77f3db Doppler 5.0 PEF binary: Doppler 5.0
0xf780000 - 0xf796067 Doubler 5.0 PEF binary: Doubler 5.0
0xf797000 - 0xf7af0a7 Enigma 5.0 PEF binary: Enigma 5.0
0xf7c1000 - 0xf7d27af L1 5.0 PEF binary: L1 5.0
0xf7d3000 - 0xf7e4eb3 L2 5.0 PEF binary: L2 5.0
0xf80c000 - 0xf81e7b7 MaxxBass 5.0 PEF binary: MaxxBass 5.0
0xf81f000 - 0xf830cbf MetaFlanger 5.0 PEF binary: MetaFlanger 5.0
0xf831000 - 0xf844ecb MondoMod 5.0 PEF binary: MondoMod 5.0
0xf845000 - 0xf862aff PAZ 5.0 PEF binary: PAZ 5.0
0xf87a000 - 0xf889fff com.apple.iokit.IOUSBLib 2.8.1 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0xf895000 - 0xf8a999f Q10 5.0.1 PEF binary: Q10 5.0.1
0xf965000 - 0xf977087 RBass 5.0 PEF binary: RBass 5.0
0xf9d1000 - 0xf9e3fff com.paceap.iokit.iLokSupport 5.7.2 /Library/Application Support/PACE Anti-Piracy/iLokSupport.bundle/Contents/MacOS/iLokSupport
0xfb9c000 - 0xfbaf117 RCL 5.0 PEF binary: RCL 5.0
0xfbb0000 - 0xfbc397f RDeEsser 5.0 PEF binary: RDeEsser 5.0
0xfbc4000 - 0xfbd6e63 RenAx 5.0.1 PEF binary: RenAx 5.0.1
0xfbd7000 - 0xfbe9fd7 REQ 5.0 PEF binary: REQ 5.0
0xfbea000 - 0xfbfa4d3 RVox 5.0 PEF binary: RVox 5.0
0xfbfb000 - 0xfc0dbdf S1 5.0 PEF binary: S1 5.0
0xfc0e000 - 0xfc2659b SuperTap 5.0 PEF binary: SuperTap 5.0
0xfc27000 - 0xfc3fad3 TrueVerb 5.0 PEF binary: TrueVerb 5.0
0xfc40000 - 0xfc5a5d7 UltraPitch 5.0 PEF binary: UltraPitch 5.0
0xfc5b000 - 0xfc6d4e7 XClick 5.0k PEF binary: XClick 5.0k
0xfc6e000 - 0xfc816f7 XCrackle 5.0 PEF binary: XCrackle 5.0
0xfc82000 - 0xfc9572f XHum 5.0 PEF binary: XHum 5.0
0xfc96000 - 0xfcab107 XNoise 5.0 PEF binary: XNoise 5.0
0xfcac000 - 0xfcc2c67 C4 5.2 PEF binary: C4 5.2
0xfed1000 - 0xff4ffff com.Waves.MAS.plugin.shell WaveShell-MAS 5.2NSrc2.1 (5.2) /Library/Audio/Plug-Ins/MAS/WaveShell-MAS 5.2.bundle/Contents/MacOS/WaveShell-MAS 5.2
0xffbb000 - 0x102afcd9 WavesLib 5.2 NS rc2 PEF binary: WavesLib 5.2 NS rc2
0x102d4000 - 0x102f1a8f L3 5.2 PEF binary: L3 5.2
0x102f2000 - 0x1030df7f LinEQ 5.2 PEF binary: LinEQ 5.2
0x1030e000 - 0x1032cdc7 LinMB 5.2 PEF binary: LinMB 5.2
0x1032d000 - 0x10350ca7 Morphoder 5.2 PEF binary: Morphoder 5.2
0x10434000 - 0x10450c47 RChannel 5.2 PEF binary: RChannel 5.2
0x1097b000 - 0x1099b9a7 RVerb 5.2 PEF binary: RVerb 5.2
0x1099c000 - 0x109c8327 SoundShifter 5.2FinishCreateSelf__14CMorphKeyboardFv PEF binary: SoundShifter 5.2FinishCreateSelf__14CMorphKeyboardFv
0x109c9000 - 0x109e1447 TransX 5.2 PEF binary: TransX 5.2
0x109e2000 - 0x10a4efff se.propellerheads.rewire.library 1.7 /Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle/Contents/MacOS/ReWire
0x10ab6000 - 0x10c66fff net.telestream.wmv.advanced 2.3.2.6 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x10ca8000 - 0x10d10fff com.apple.AppleProResDecoder 2.0 (223) /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0x10d14000 - 0x10d54fff com.apple.applepixletvideo 1.2.18 (1.2d18) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x10d57000 - 0x10fd6fff se.propellerheads.reason.engine 4.0.1 /Applications/Reason/Reason.app/Contents/PlugIns/Reason Engine.plugin/Contents/MacOS/Reason Engine
0x11a86000 - 0x11aaffff com.MOTU.plugin.ControlSurface.HUI 1.3 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/HUI.bundle/Contents/MacOS/HUI
0x11ad7000 - 0x11b04fff com.MOTU.plugin.ControlSurface.MackieControl 1.3 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/MackieControl.bundle/Contents/MacOS/MackieControl
0x11b38000 - 0x11b6bfff com.MOTU.plugin.ControlSurface.SAC_2_2 3.2 (1.0) /Library/Audio/Plug-Ins/MOTU Control Surface/SAC DP Driver.bundle/Contents/MacOS/SAC DP Driver
0x11b8b000 - 0x11b98fff com.MOTU.plugin.ControlSurface.TranzPort TranzPort version 1.04 (1.04) /Library/Audio/Plug-Ins/MOTU Control Surface/TranzPort.bundle/Contents/MacOS/TranzPort
0x1255ae00 - 0x1255adff RBassProcess PEF binary: RBassProcess
0x12562a00 - 0x125629ff RChannelProcess PEF binary: RChannelProcess
0x70000000 - 0x700fdfff com.apple.audio.units.Components 1.4.7 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.85 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.11 (368.35) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aea000 - 0x90b5cfff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.19 (681.21) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f92000 - 0x90fd4fff com.apple.CFNetwork 4.0 (129.24) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe9000 - 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91011000 - 0x91092fff com.apple.SearchKit 1.0.8 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d8000 - 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91112000 - 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib
0x91123000 - 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dd000 - 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ed000 - 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib
0x913f9000 - 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91434000 - 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91444000 - 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fc000 - 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fe000 - 0x91536fff com.apple.AE 312.2 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91551000 - 0x91623fff com.apple.ColorSync 4.4.13 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91676000 - 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174e000 - 0x91805fff com.apple.QD 3.10.28 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91842000 - 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918cf000 - 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91904000 - 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193c000 - 0x9197efff com.apple.LaunchServices 183.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9199a000 - 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bc000 - 0x91a02fff com.apple.ImageIO.framework 1.5.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a19000 - 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b2e000 - 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b48000 - 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6c000 - 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c72000 - 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c78000 - 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce7000 - 0x91d02fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d07000 - 0x91d0afff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d0c000 - 0x91dfafff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91e19000 - 0x91e57fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91e5e000 - 0x91e5efff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e60000 - 0x91f45fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f4d000 - 0x91f6cfff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fd8000 - 0x92046fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x92051000 - 0x920e6fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x92100000 - 0x92688fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926bb000 - 0x929e6fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a16000 - 0x92b04fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b07000 - 0x92b8ffff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bd0000 - 0x92e03fff com.apple.Foundation 6.4.12 (567.42) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f36000 - 0x92f54fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f5f000 - 0x92fb9fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fd7000 - 0x92fd7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fd9000 - 0x92fedfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93005000 - 0x93015fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93021000 - 0x93036fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93048000 - 0x930cffff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930e3000 - 0x930eefff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930f8000 - 0x93126fff com.apple.openscripting 1.2.7 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93140000 - 0x9314ffff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9315b000 - 0x931c1fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931f2000 - 0x93241fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9326f000 - 0x9328cfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9329e000 - 0x932abfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x932b4000 - 0x935c2fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93712000 - 0x9371efff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93797000 - 0x93797fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93799000 - 0x93dccfff com.apple.AppKit 6.4.10 (824.48) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94159000 - 0x941cbfff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94204000 - 0x942c9fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9431c000 - 0x9431cfff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9431e000 - 0x944defff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94528000 - 0x94565fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x9456d000 - 0x945bdfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945c6000 - 0x945dffff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9478d000 - 0x9479cfff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x947a4000 - 0x947b1fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x947f7000 - 0x94810fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94817000 - 0x94b4afff com.apple.QuickTime 7.6.4 (1327.73) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94c32000 - 0x94ca3fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x9507a000 - 0x95097fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x95489000 - 0x95489fff com.apple.DiscRecording 3.1.3 (???) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x9548b000 - 0x9550efff com.apple.DiscRecordingEngine 3.1.3 /System/Library/Frameworks/DiscRecording.framework/Versions/A/Frameworks/DiscRecordingEngine.framework/Versions/A/DiscRecordingEngine
0x9553b000 - 0x95581fff com.apple.DiscRecordingContent 3.1.3 /System/Library/Frameworks/DiscRecording.framework/Versions/A/Frameworks/DiscRecordingContent.framework/Versions/A/DiscRecordingContent
0x95b4d000 - 0x95b7ffff com.apple.PDFKit 1.0.4 /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x960c5000 - 0x960dbfff libJapaneseConverter.dylib /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x960dd000 - 0x960fdfff libKoreanConverter.dylib /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x9610b000 - 0x96119fff libSimplifiedChineseConverter.dylib /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x96121000 - 0x96134fff libTraditionalChineseConverter.dylib /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x966b6000 - 0x966f5fff com.apple.audio.MIDI.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x969e1000 - 0x96a00fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9725d000 - 0x9726afff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x97ce5000 - 0x97db6fff com.apple.QuartzComposer 1.2.6 (32.25) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x97e33000 - 0x97e33fff com.apple.quartzframework 1.0 /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x97f64000 - 0x97f86fff com.apple.DiscRecordingUI 3.1.3 /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
0x983ad000 - 0x983bafff libbz2.1.0.dylib /usr/lib/libbz2.1.0.dylib
0x986af000 - 0x992e8fff com.apple.QuickTimeComponents.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9954b000 - 0x9954ffff com.apple.QuickTimeH264.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x9a22a000 - 0x9a248fff com.apple.OpenTransport 2.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x9a2c3000 - 0x9a2c4fff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0x9bc48000 - 0x9bc68fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x9fef8000 - 0x9ff9afff com.apple.QuickTimeImporters.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x9ffb8000 - 0x9fff7fff com.apple.QuickTimeFireWireDV.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
Re: DP 6.03 ( and 7.12 ) crashes after 4/5 hrs of work.
What are you doing when it crashes? You say this is happening with 7.12 but I only see 6.03 logs. Not that it will necessarily solve things, but I'd bet 7.12 is much more stable than 6.03. I'm not a programmer and there aren't too many on the board, so speaking for myself, simply posting your crash logs is not too useful for me. Good that you went 12 hours without a crash after turning off spotlight though.
How often are you crashing, BTW? I sometimes crash inexplicably and I'm not sure why.
One thing I would suggest you do, and I don't know if it will solve your problem but test your RAM with this:
http://www.kelleycomputing.net/rember/" onclick="window.open(this.href);return false;
I had some odd crashes with my G5 a while back and it turned out I had some borderline RAM that failed Rember first time through. I had to open the machine and remove and put back pairs of DIMMs until the machine passed to figure out which were the bad sticks. I bought mine at The Chip Merchant and they have a lifetime guarantee which is typical for most places that sell RAM. If you know where you bought it, they'll probably swap them for you.
This may not be your problem, but it is always good to verify that your RAM is up to par.
sugardilly
Hey James,
Thanks for responding. I posted the info regarding the removal of Spotlight which was separate from Sestopiano.
It just happens that I'm experiencing the same problem. I'm running DP 6.03 and my crashing is happening relatively fast. A few minutes after disabling Spotlight I had a few crashes.
I don't know how to read the logs either but I'm hoping someone could read it and give me an accurate resolution. I'm in the middle of mixing a song and it's really annoying.
I have repaired Permissions, Defragged, and now disabled Spotlight. I will try the removal of the Dimms.
Machine Name: Power Mac G4
Machine Model: PowerMac3,6
CPU Type: PowerPC G4 (3.2)
Number Of CPUs: 2
CPU Speed: 1.25 GHz
L2 Cache (per CPU): 256 KB
L3 Cache (per CPU): 2 MB
Memory: 2 GB
Bus Speed: 167 MHz
Boot ROM Version: 4.4.7f1
I'll appreciate any further help you can offer.
Thanks a lot for your response.
Test the RAM with Rember first. If it tests okay there's no need to remove DIMMs. :)
So this has been going on since May 13? And have either of you contacted MOTU? You can only get so much help here but these are serious problems. There are a few things no one has suggested, like reinstalling from the original DP disks - assuming you have these? If you installed from a downloaded copy off the www it is possible it is corrupted or has a virus.
It would also seem like a few simple diagnostic procedures are in order. Repair permissions, clean caches, run daily, weekly, and monthly routines. Yadda yadda yadda...
Log into you MOTU account if you have one and set up a techlink if the call is too expensive to the good old U. S. of A.
Have I left anything out? You betcha! But I don't want to get anyone's knickarrrs in a knot just yet...
