VST in DP 7.12
AleCerto
VST in DP 7.12
Post by AleCerto »
I have to run some VST virtual instruments in DP 7.12.
Have I to use some wrapper plug-in or what?
Could you suggest the best - and cheaper ;-) - way to run the VST plug-ins in DP 7?
TIA,
Ale
MacPro QuadCore 2.66GHz, 16 GB RAM, OS 10.11.6 & 10.8.5, DP 9.12 & 8.07 , PT 12.7 & 10.3 & 11.1, MachFive 3.21, Komplete10, Waves Diamond 9, PTHDX+HD I/O, MTP AV
adriano
Re: VST in DP 7.12
Post by adriano »
Hi Ale.
Si. L'unico modo di usare VST con DP, ti serve il wrapper
Clicca i links di sotto
http://www.refusesoftware.com/products/feature/3" onclick="window.open(this.href);return false;
http://www.audioease.com/Pages/wrapper/wrapperMain.html" onclick="window.open(this.href);return false;
Spero che questa soluzione funziona senza problemi
Adriano
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
Dave Bourke
Re: VST in DP 7.12
Post by Dave Bourke »
Note that Audioease's VSTWrapper has never been updated to run on Intel Macs.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
newrigel
Re: VST in DP 7.12
Post by newrigel »
Every day I see new AU VI surfacing. There's thousands of AU's alternatives today that it renders wrappers pretty much obsolete... back in the day you needed them, today there are excellent AU alternatives, or the developer provides dual platform support.
carrythebanner
Re: VST in DP 7.12
Post by carrythebanner »
Rather than using a VST wrapper inside of DP, you could also consider running another app alongside DP that natively hosts VST plug-ins — Plogue Bidule, for example.
funkyfreddy
Re: VST in DP 7.12
Post by funkyfreddy »
Dave Bourke wrote:Note that Audioease's VSTWrapper has never been updated to run on Intel Macs.
Kind regards.
Ah...... so that's the problem! Thanks, Dave! LOL, guess I am a little dense at times.... :mrgreen: :D :idea: :roll:
MacBook Pro (16-inch, 2019) 2.3 GHz 8-Core Intel Core i9 16 GB RAM OSX 12.7.1 Monterey
UAD Apollo Quad, some Waves, Soundtoys, Digital Performer 11.34, Reason 13, iZotope 11, and lots of real instruments to play.
KEVORKIAN
Re: VST in DP 7.12
Post by KEVORKIAN »
carrythebanner wrote:Rather than using a VST wrapper inside of DP, you could also consider running another app alongside DP that natively hosts VST plug-ins — Plogue Bidule, for example.
+1
I am using Plogue to run VST instruments via Rewire. Connection is easy and sync is flawless.
SixStringGeek
Re: VST in DP 7.12
Post by SixStringGeek »
There is a wrapper out there but it isn't for the casual end user. You might be surprised to find that a large number of VI's on the market that are cross platform are actually written as VST's and then wrapped using Symbiosis. The documentation lists Addictive Drums as one such instrument.
If you are a developer, it is possible to use this package to build AU versions of VSTs even without the source code, but it is tedious and technical.
DP 11.newest on MacBook Air M2 24/2T
Korg Kronos Klassic Keyboard 88, Line 6 Helix
Elio
Re: VST in DP 7.12
Post by Elio »
Scusa la curiosità ma quali VST vuoi usare ? con Independence puoi caricare sia strumenti che effetti http://www.yellowtools.us/cp21/cms/index.php?id=930" onclick="window.open(this.href);return false;
Elio Morabito
newrigel
Re: VST in DP 7.12
Post by newrigel »
I think the key to computing is to first, find the applications you want to use or NEED to use to achieve your goals and then... use the platform that supports it best... not the other way around. My DAW is Mac only so I use a Mac! There are so many AU alternatives today you don't even need to worry about a VST that isn't available as an AU or that makes any AU obsolete. If there is then you need to change platforms then. There's always boot camp :roll: .
