crduval wrote:Zed, I goofed and left off a "d" ("Zed" vs. "Zedd") in the referral section during my order - sorry about that - with all the good info that you've provided, you deserved credit. Maybe the nice folks from IK reading these posts will fix it on the back end.
Thanks so much for thinking of me. I appreciate it!
Fortunately, I have been an eSoundz customer for almost 7 years, and Allen knows me by each of my names, and even recognizes my voice on the phone!
Since I think the ePointz are applied manually by Allen, I'm pretty sure that he will make the correction when he sees it.
Dan Walsh wrote:Here is the dumb newbie question of the day--should I be installing these libraries on a separate harddrive, or is it ok to just put em' on the drive in the Mac Book Pro? I run my external drives thru USB 2.0.
Just wonderin' what is the best way....
Welcome Dan! I think these instruments and SampleTank itself make such a small footprint that it doesn't matter where you install them. And if you want to change the location at a future date, all you do is copy the library to a new location and then point SampleTank to the new folder location. This will NOT cause your projects to forget which instruments were used or anything like that. It is really easy to change (and even to reinstall the ST whenever you have to), so you don't have to worry about it AT ALL.
Install wherever convenient, and adjust later if there happen to be any performance issues.
