Transpose an MP3
Transpose an MP3
Is there a way to drop an audio file down like 1 whole step? I tried the transpose function but it didnt sound too hot
DP 6.02 & 6.03
imac 2.8GHz Quad-Core Intel Core i7 8 gig RAM
Macbook 2.4 GHz Intel Core 2 Duo 4 gig RAM
Plugins - Superior Dummer 2.0 / Machfive 2.0 / BPM / Electric Keys / Symphonic Instrument / Kontakt Sounds / Ozone 4 / Wavearts plugins (masterverb, multidynamics, trackplug) / Yamaha Motif XS6 / Yamaha Motif ES7
My Two Bands
http://www.formerlythree.com
http://www.theinnocencelive.com
My Two Bands
- Mark Walmsley
Re: Transpose an MP3
I had to do this same thing yesterday. DP didn't cope very well. I ended up using Melodyne which was much better for transposing a whole mp3 mix. I have heard some people praise the apple pitch shift audio unit plug that you will already have installed...
Otherwise you could download the trial version of Reaper which apparently has licensed a very good pitch shift algorithm.
Good Luck!
Good Luck!
Mac-Pro 8 core 2010, OSX 10.9.5, Motu DP 8.07, Apollo firwire, TC Powercore Firewire. User since Performer on Macplus in 1988
- buzzsmith
Hi, Mark.Mark Walmsley wrote:I had to do this same thing yesterday. DP didn't cope very well. I ended up using Melodyne which was much better for transposing a whole mp3 mix. I have heard some people praise the apple pitch shift audio unit plug that you will already have installed...
Good Luck!
I, too need to transpose individual mono tracks for a project up a step. I downloaded Reaper, but I still get that "garbly" sound on sustained piano and I did try different parameters and pitch shift algorithms.
I also downloaded the demo of Melodyne Studio and it seems to be better and clearer.
On occasion, I also need to transpose an entire stereo mix either up or down.
Any other apps or plugs come to mind for transposition and time manipulation or is Melodyne the go-to for this?
Buzzy
EDIT: Just tried the Apple AUPitch (I forget about these Apple plugs), and it actually sounded pretty decent on mono tracks. I might be able to make this work, but I'd still be interested in your comments.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I can't help but wonder if transposing an MP3 is going to sound worse than if one had access to the original lossless file?
- buzzsmith
Transpose an MP3
In my case, they are not MP3s. Just regular DP audio.
Mono and some stereo.
Thanks...
Buzzy
Thanks...
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- adriano
Hello forum,
Spencer4t, try this app "Transcribe" it has a 30 day trial an d I believe it has no restriction
It's worth a shot:
http://www.seventhstring.com/xscribe/screenshots.html" onclick="window.open(this.href);return false;
Adriano
It's worth a shot:
Adriano
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
- Mark Walmsley
the only other app i can think of to try is 'amazing slow downer'
But Melodyne is the best I have used.
If you're dealing with 320k mp3s, there should be less of an issue with quality. But we all know that a 320k mp3 is fairly rare for as decent as it is.James Steele wrote:I can't help but wonder if transposing an MP3 is going to sound worse than if one had access to the original lossless file?
Generally speaking, in this day an age of "faster-smaller-easier", doing a serious project centered around an mp3 format could create as many problems as it solves.
There are sites like yousendit which will let you upload/download up to 100MB for free. With that kind of service out there, it's better to send an AIF or BWAV for audio files 44.1 less than 10 minutes long.
Polyphonic material doesn't do too well regardless what you use... especially an MP3. Try a raw format, your result will be better by far.spencer4t wrote:Is there a way to drop an audio file down like 1 whole step? I tried the transpose function but it didnt sound too hotThanks
- Dwetmaster
Apple pitch is the way to go
- buzzsmith
Transpose an MP3
The only thing that bothers me in my, admittedly, limited use of AUPitch is the formants.Dwetmaster wrote:Apple pitch is the way to go
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
