Thanks for your help!
Check the MIDI Input Filter dialog, which is accessible from the Setup menu.steve_56 wrote:Using DP6 with Arturia Minimoog V installed as a plug in. When using the Minimoog as a stand alone the aftertouch works fine, but I can't get it to work in DP.
Neither mod wheel nor pitch bend are system exclusive events. Mod wheel is a control change and pitch bend is a unique type of event (although it's practically a 14-bit control change).steve_56 wrote:The mod wheel and pitch bend are working fine so I know the sysex is turned on - just can't seem to find the settings in DP to trigger the after touch.
