Whats .acdi?
javierdh
Whats .acdi?
Post by javierdh »
I did a bounce to disk > file format audio cd disk image, tracks based on cd markers. The file created is a .acdi, Toast will not accept it, how do I burn a CD of it?
J
javierdh
Re: Whats .acdi?
Post by javierdh »
FYI
I was unable to open it (.acdi) in any CD burning software, but clicking (opening) the file with the default, which is DP, takes it directly to the burning procedure of DP and did the cd with tracks as expected.
Schweats
Re: Whats .acdi?
Post by Schweats »
Did you use the CD burn utility that resides in your Disk Utility folder which is part of OS X ?
remember, you must make a disk image first , then hit the 'Burn' button for it to work
HTH - Schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
carrythebanner
Re: Whats .acdi?
Post by carrythebanner »
An acdi file is an audio CD image file for DP. Other apps won't read it as-is, though since it appears to be just an AIFF file with some extra stuff in it, you could change the extension to .aiff and treat it as a normal audio file.
javierdh
Re: Whats .acdi?
Post by javierdh »
Thanks to all!
J
