Each time I play a note or something, both on the master keyboard and MIDI guitar, the notes I'm playing sound very late in time!
If I record on a MIDI track (hardly trying not to listen to the click because of the latency and without input quantize) and I play it back, what I recorded sounds in time - in other words, it looks like DP records MIDI data properly and in time.
If I use MachFive2 (or NI Kontakt4, and so on) as a stand-alone application, I have a "normal" and acceptable latency (a few ms): what I'm playing sounds practically "in time".
I have this awful latency problem only within DP7 (beside DP7.11, I've also tried with DP7.02 and DP7.1 but there's always the same latency problem).
I've looked for information/solutions both in the manuals and in the Motunation forums but I was not able to find a solution out.
I do need to solve this issue as soon as possible, otherwise I can't use DP almost at all (and on Friday I've to start a new gig)!
Could you please help me?
Have I to set some "hidden" preferences or other?
TIA,
Ale
