Quicktime Move Lag
ssummerford
Quicktime Move Lag
Post by ssummerford »
Hi
Has anyone had this problem You're working on a project with a QT movie, which plays fine at normal speed and is locked to transport, frame rate is right, and for some reason, a certain chunk of it plays everything in slow motion? It was working fine, then after some back/fwd scrubbing it only plays back at like 1/2 speed--everything is slowed down. I have to close my project to get it to come back to normal.
Any thoughts?
Steve
williemyers
Re: Quicktime Move Lag
Post by williemyers »
Steve,
what kind of audio interface are you using? If it's a Digi product (002, mBox, etc.) and it has installed the most recent DigiCoreAudio driver, this driver will cause QT to behave strangely when locked to DP.
just a thought...
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
Also, are you playing back in the DP movie window or on an external monitor via FW?
ssummerford
Actually, it is a DIGI002r. Hmmm...any suggestions on what to do about that? I've never heard of such an issue. I'm running DP 7 in Leopard, DIGI002r with the PT 7.4 drivers (I haven't paid to upgrade PT6.9 to run with Leopard, but am using the free hardware update. I'm running QT in a DP session locked to transport, not on an external FW video.
Am I essentially screwed with the DIGI interface?
Steve
williemyers
ssummerford wrote:Am I essentially screwed with the DIGI interface?
Steve
maybe yes, maybe no!
In my case, here's how I got around it.
I have my 002R running in to a Mackie mixer. In the past, I would have set the Mac's System Audio (SystemPrefs>Sound>Output) to run thru the 002R. But with this CoreAudio glitch, the workaround is to change SystemPrefs>Sound>Output from Digi002 to BuiltInAudio, and then run an audio cable out of the back of the Mac and in to the Mackie.
Then, when I open a QT movie in DP, there's no delay/glitch in playing the movie.
You might want to give it a try?
~me
