MIDI Keyboard
MIDI Keyboard
I have been using DP6 for about six months. I have barley scratched the surface of this program. I have the basics for setting up and recording audio. I was recently given an M-Audio ultra thin 25 key MIDI interface. Could someone explain how to get this to work in
simple terms. I am a drummer and very new to digital audio technology. I have looked in the
manual but its information overload. Thanks in advance
Its all about the music!
Re: MIDI Keyboard
M-Audio does not a make a device called an 'ultra thin 25' that is listed on their website.
Is the device an Axiom Pro 25 , or an Axiom 25 , or an Oxygen 25 ?
Please confirm whether your device is any of these. If it is , you connect the device to your computer via a USB cable. Once you hook it up , what do you want this device to do ?
Once you answer the last question, I can make further comments
HTH - Schweats
HTH - Schweats
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
Re: MIDI Keyboard
I am using it for know to learn how to play piano. I will get a proper keyboard once I have money. I would also like to use it for making percussion loops and other type of loops to play with and to record. I hope that is a better explanation. Sorry about posting wrong info.yesdog wrote:My bad, its an O2 25.
Re: MIDI Keyboard
No, sorry , this device will not do what you think it will do going by your statement.yesdog wrote:I would also like to use it for making percussion loops and other type of loops to play with and to record
To make loops , in general, you need a software or hardware sampler. The O2 25 is a tactile device
for changing whatever parameter you choose and assigning that parameter to a knob or slider. One would use the
keyboard section to trigger a note that has a loop assigned to it.
Additionally, when you have DP's mixer window open , you can assign and manipulate sliders, mutes, and aux sends to any of the tracks displayed amongst a whole lot of other stuff.
The 02 25 does not record audio of any kind , AFAIK. If you haven't already , I'd read up on the device at the M-Audio website. Perhaps , a clearer picture of what the O2 25 is and what it is used for is displayed there.
HTH - Schweats
Schweats
Re: MIDI Keyboard
This is what I have http://store.apple.com/us/product/TV518 ... TA4NDQwMjE" onclick="window.open(this.href);return false; I just want to know how to set it up with DP6.Schweats wrote:No, sorry , this device will not do what you think it will do going by your statement.yesdog wrote:I would also like to use it for making percussion loops and other type of loops to play with and to record
HTH - Schweats
Re: MIDI Keyboard
You don't mention the system your using but I'll assume it's a modern mac. Just plug a USB cable from the O2 to the computer. You can verify installation by going to Utilities -> Audio MIDI Setup. You should see the O2 listed there under the MIDI tab.
In DP create a Instrument track with a Virtual Instrument in it. Set it's audio out to a pair of outputs on your audio interface. Then create a MIDI track with it's input set to the 02 and it's output set to the VI you created (ch1). Play the keyboard and it should play the VI.
Ken-
Ken-
My Gear: MacPro 2.8ghz Quad (2010), 12 GB RAM, 4 internal HDs, OS 10.6.5, DP 7.21, MOTU 2408mkIII, MTP AV
