Wiper at start and the end of event
Dears all,
i need to fast place the playhead (wiper) at the start or the end of a MIDI event i select.
Is in DP a command like "go to selection start" "go to selection end" ?
Thanks in advance.
-A
Thanks in advance.
-A
- philbrown
Re: Wiper at start and the end of event
Go to the Commands window and search for 'Selection' there. There are so many commands available there no one could possibly memorize them all. The search function is your friend.antongiulio wrote:Dears all,
Thanks in advance.
-A
Hi thanks but seems to be not possible to place playhead at start or end selection....
-A
-A
Command-4 and command-6 are Play From Selection Start and Play From Selection End respectively. If you have the transport paused (keypad 2) when you press these, the wiper will go to the start or end of the selection and pause. Perhaps that's not exactly what you were looking for, but I think it's a fair work-around.
So you could hit Keypad 2, Command-4, Keypad 0(stop), and that would put you at the beginning of the selection. Substitute Command-6 for end of selection.
- philbrown
Great job Phil. I just tried it and if you pause first this works just fine. I'll will probably use this trick now.Phil O wrote:Command-4 and command-6 are Play From Selection Start and Play From Selection End respectively. If you have the transport paused (keypad 2) when you press these, the wiper will go to the start or end of the selection and pause. Perhaps that's not exactly what you were looking for, but I think it's a fair work-around.
Great !
Thanks.
-A
Thanks.
-A
Glad I could help.
