zed wrote:It may be that you are right... but that was not my experience.Bowman wrote:That being the case, and in light of everything else that has been posted here, it may be time to reinstall everything: new hard drive, operating system, the latest drivers, your usual software. Take your time and test everything thoroughly as you do it. The long way round, maybe, but considering how long this has been going on, it might be the only solution left. And hard drives are relatively cheap these days.
When I got my new MacPro, I spent days setting it up, installing everything from scratch, testing as I went along, being careful as hell. And when I finally got to the point of trying to do some work, I had the worse audio pops and clicks ever. I couldn't make an audio edit without there being a pop at the joint, whether the waveforms were misaligned or not. And a bunch of other things had me troubleshooting for months.
All I'm saying is that no matter how careful you are and determined to do everything right so that you will have a clean and healthy setup, your problems may not disappear--but they could. This stuff is supposed to work without so much trouble, so it is more likely that there is one little thing that is messing everything else up... and something that may very well be there even if you install everything from scratch.
One thing you didn't mention, okcrounders, is anything to do with your electricity. Do you have any electrical issues in your studio area? I have something weird going on with mine, and it does cause weird noises in my system, especially noticeable when using headphones. I am considering the purchase of an electrical conditioner to see if that eliminates any of my audio issues.
Tried a power conditioner today (I borrowed one from a friend). Didn't fix the problem.
