HI hat muting simplified
OK I tried per my previous post to figure that all out, and read the manual. What the heck? this should be step 1 step 2 step 3 push enter and done. I cannot get it done. I DONT want to learn how to program, do layers etc. this is the only thing I need. HELP I want step by step to get my 3 general MIDI hats from gigastudio to MUTE each other out. THANKS!!!!!!!!!!!!!!!!!!!!!!!
Re: HI hat muting simplified
http://www.soundonsound.com/sos/jul08/a ... p_0708.htm" onclick="window.open(this.href);return false;
choke groups
choke groups
David DeLizza
4-core nehalem macpro, 6 gb ram, dp5,6,7, motu 896hd, axiom61, reason 4, bunch o' plugs.
Open the list editor. Find the keygroups that you want to be in the group. Set the Group parameter for each of those keygroups to the same nonzero number. Done.
THANKS, that worked! Sort of a pain tho as GigaDrums have 3 layers of each hat and each hat with multiple samples BUT, it worked. I dont use DP, I use Ableton and Harrison Mixbus, so the DP primer altho looks nice, does not help me.
