The next day on a completely different project, i used the Transpose (CMD+9) on a sound bite and the same things happened, however when I used Spectral Effects it did not happen. What could be causing this shift in timing of the play back of these soundbites. Merging the sound bit or Bouncing to Disc did not correct the problem. I haven't installed any new softwear.
I'm using DP 6.02 on Mac OS 10.5.8
Thank you in advance
