low input signal ultralite
frolix
Post by frolix »
Hi all,
I'm trying to hook up my AKG perception 220 to one of the 2 XLR inputs but I'm getting a really weak signal in Live (8.1.1). Even with the trim on max I get almost nothing. 48V is on. I'm kinda new to this and am probably missing something but I need it to work soon and can't find any solution ... Anybody got some suggestions?
Respectfully,
Frolix
akumpis
Re: low input signal ultralite
Post by akumpis »
I'm not too familiar with this interface, but chances are that you need to make sure you are using Mic and not Line level. There should be a switch or option that allows you to select between Mic and Line level. Hope this helps.
stephentayler
Post by stephentayler »
Have you checked to see if the Pad is in circuit? I am not sure how it is switched on the Ultralite.... but the indicator light should show if it is on or off, make sure it is off.
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
frolix
Post by frolix »
tx for the response!
Pad is off i'm sure ... can't find any button or switch to change to 'mic-level' ... Mics are working fine on my mbox, so it's not them ... frustrating problem
frolix
Post by frolix »
solved ...
restored to factory settings ... don't know what went wrong but now it works!
r
frolix
