New XP software
New XP software
I am looking for a new piece of recording software im not looking to spend more than necessary. I am opening a local record company and im working on enhancing my studio. i've currently got a 16 track mixer a guitar port and a MOTU 1224 and PCI-324 interface. I am using Cool Edit Pro but i've heard it isn't the best....anyone have any suggestions i've heard cakewalk is good but i don't know which version....any advice would be appreciated thanks
john
john
Re: New XP software
If you are currently using CE I would suggest that you upgrade to Adobe Audition. Adobe purchased CE and have made a good product a whole lot better. I am using version 1.5 with 2408MK3 and it works flawlessly.
Re: New XP software
thank you...i'll look into it.....i appreciate the input
Re: New XP software
I am also a fan of Audition, but I might suggest you take a look at the Samplitude rental option. http://www.samplitude.com/de/sfr.htm
Re: New XP software
I use Sonar pro4 and love it. Full of plug-in effects!!! Easy to use. lmoe
DeskTop Productions
Mansfield, Ohio
Mansfield, Ohio
Re: New XP software
you can try cubase SX or SL
now in ver 3
easy to use and any plugins.
also it uses well the industry standart plugin format VST
good luck
now in ver 3
good luck
Re: New XP software
you will be pleasantly suprised with ntrack
www.fasoft.com
www.fasoft.com
Re: New XP software
Cakewalk Sonar 4 Producer is one of the finest PC recording and sequencing packages available. It boasts the most flexibly dynamic bussing, 192khz and higher capable (Cubase is limited to 96) POWR3 dithering and more. If you're thinking about Cakewalk, and imho you SHOULD, look at Sonar 4 Pro.
Just my $0.02
Just my $0.02
