Radical SAC 2 and Snow Leopard
lunaticDP
Post by lunaticDP »
Hi,
I've ported to snow leopard and can not get my radical sac going.
Has anybody running 10.6 with dp7.1 AND the radical sac?
thankful for any help
lu
MacPro 3,3GHz 6-core, 16GB, OSX 10.7.5, dp8, mach five 3, msi, motu 2408mk3, 2x 1224, 308, melodyne editor, stylus rmx, omnisphere, trilian etc.
rodger1811
Re: Radical SAC 2 and Snow Leopard
Post by rodger1811 »
Works great for me. However, FYI, I am using it via MIDI and not USB. No delays and no problems.
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
lunaticDP
Post by lunaticDP »
rodger1811 wrote:Works great for me. However, FYI, I am using it via MIDI and not USB. No delays and no problems.
Great to hear, I also tried it via MIDI, but the Sac doesn´t showup in the audio/MIDI setup; any idea?
rodger1811
Well first of all, you have to have it connected to a properly configured MIDI device. I'm not sure what you're using for your MIDI device but make sure that's done first You also need to connect the SAC to your MIDI device via the AUDIO/MIDI setup utility. Drag the input and output accordingly. Secondly, make sure that you've provisioned for your SAC in DP. You do this in the "setup" menu.
PS, under the help menu, there is help for you via the "Control Surfaces Help" menu.
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU 24I/Ox2
MOTU MIDI Timepiece
lunaticDP
Post by lunaticDP »
.....Drag the input and output accordingly.
I forgot to connect the in/outputs....
thanks a lot; everything fine again!!!!
cheers
lu
