You're right! I took the nudge up and down arrows away in the "More Edit" Commands list, and now the up and down arrows work in the record enable column again.... The ability to nudge MIDI notes up and down is cool, but I use the rec enable much more often, so I'll stick with this arrangement for now.Dan Worley wrote:Yes, good point. Go to Commands and try to assign the Up arrow key to something and you will get an alert telling you what other commands are using it. Cancel out of that and go in and remove the Up/Down arrow from the conflicting commands.
Thanks for the workaround.
