Hey everyone,
Does anyone have any pros/cons to leaving a machine running 24/7 or should I shut it down after I am finished using it for the day?
Thanks,
Jody
Turn off machine or leave it on
Re: Turn off machine or leave it on
IMHO think green. Turn off.
Mac Pro 1.1, SL 10.6.8, 13 gigs ram, DP7, 2 MTP-AV-USB, MTP-AV serial, Microlite, 828mk2, 828mk3, HDX-SDI, 7 other Macs
This question has been discussed here before. Try the search feature. Short version:
Main advantage of turning machine off - less power consumption.
Main advantage of leaving it on - Macintosh runs some periodic maintenance routines, some of them in the wee hours. But, you can easily run these routines manually using terminal. (check out "periodic" command)
Be green; turn it off. Save money: turn it off. Leave youself open to transitent spikes 24/7; leave it on.
No real advantage to leaving it on 24/7, IMO.
