Can't load any project in dp7! [RESOLVED]
legodo
Re: Can't load any project in dp7! [RESOLVED]
Post by legodo »
Ok same problem and same solution. Thank you very much :D
cchord59
Post by cchord59 »
Anyone know why I still get the error? I need to reauthorize dp7 right?
Mac 2.66 quad, DP 7, Latest Snow Leopard, Aurora 16.
bjornln
Post by bjornln »
Speculation....
Does anyone who have / had this problem, use Migration Assistance ?
or
Did you format the startup disk ? or just installed over the old installation..
/B
cchord59
Post by cchord59 »
bjornln wrote:Speculation....
or
/B
I didn't use migration assistant, but the the startup disc I'm using now is a Carbon Copy Clone of my original start up disc. Do you think this is part of the problem?
stereotrope
Post by stereotrope »
Same problem, same solution (finding and deleting invisible DP7 authorize file). Using a Macbook and MAC OSX 10.62. Curiously, I tried to install DP7 on a XEON MacPro (10.62) and DP7 worked fine on first launch. But on my Macbook, I was unable to confirm the key binding prompt dialog box on first launch, had to force quit DP7 and was never able to create a new file on second and next launches. Deleting the invisible fine solved the "an error occured while writing to the disk...This file was created in a later version of DP and cannot be opened in this version... "
Thanks for this great forum !
newrigel
Post by newrigel »
or
/B
Did you replace the actual hard drive? Either way just use cocktail or search for invisible files by going into the finder and typing "auth" and then hitting the "+" and in the attributes go to the "file visibility" preference and then go and click the tab next to it and the dropdown will have visible or invisible or both either click both or invisible and the Auth-DigitalPerformer 7 or whatever version your using will show up... trash it and then put the CD in and launch DP and re authorize... that's it!
Dark Goob
Post by Dark Goob »
haha. I found out what caused this issue for me.
It's because I installed the 7.01 -> 7.1 update, but as per usual, the updater *does not delete version 7.01* ...
So the link in my dock, and the automatic loading of the program via LaunchBar, was opening up version 7.01 still! So I had 7.1 installed, but after that, it would not let me use 7.01 since it kept saying projects were made by a newer DP.
But once I actually changed out the link in my dock to be the 7.1 version, and forced LaunchBar to actually open version 7.1, then it worked fine. LOL!
I'm an idiot. So is my computer.
PS -- I hate iPhoto.
-=DG=-
_________
Vocals/Synths
Sawblade Painter
https://soundcloud.com/sawbladepainter
Moonbase Zeta
https://soundcloud.com/moonbasezeta
_________
2021 MacBook Pro 16" M1 Max, 64 GB RAM, 8TB
MOTU 896HD (Black Lion Mod) | MOTU 828 Mk II | Korg X2, RK-100S Mk 2 | Yamaha Electone 7000 | Behringer ARP 2600 | Alesis Photon X25 | iPad Pro 12.9" | Line6 MobileKeys 49 | SoundCraft Delta 200 16•4•4 | DP8 & DP11
